Kubota Touch Up Paint?
/ Kubota Touch Up Paint? #1
mo239
I'm not looking for a spray can, just a small bottle with a brush for a few chips, was wondering if this would be what I need for a new Kubota? Kubota Orange II Touch-Up Paint from Miscellaneous
Or, is there a good color for cars in those small bottles you can get at auto stores that would work?
/ Kubota Touch Up Paint? #2
I was roaming the local farm supply store last week (ie Fleet Farm) and noticed they had rattle cans which looked to be color matched for most farm and equipment manufactures. The only bad thing is that nobody could find the book so one could tell which can was for which brand. I know you were looking for bottle paint but in worst case spray the brush, then paint as required. I think the paint mfg was Valspar.
Robert
/ Kubota Touch Up Paint? #3
Tractor Supply has quarts, gallons, & spray. Only seen Kubota orange in quarts but that is the original Kubota orange, and saw New Kubota orange in spray can. They may be able get New Kubota orange in the quarts, just have to ask them. Kubota dealer may also have paint in quarts or larger instead of those little touch up bottles but they may have to order it too.
/ Kubota Touch Up Paint? #4
Yes there is an auto paint called (Krylon -- Chevrolet Orange 2405) it is almost an exact match and not to mention a whole lot cheaper.
Josh
/ Kubota Touch Up Paint? #5
Easiest and cheapest is to get the Tractor Supply spray Kubota New Orange and spray some in the cap or small can etcc. Then use a small model car brush etcc to touch up with. You can clean the brush with standard paint thinner.
Trying to find a small touch up applicator for Kubota might be too much time wasted.
/ Kubota Touch Up Paint? #6
I agree with ejnichol, Tractor Supply's Valspar "New Kubota Orange" spray cans match newer Kubotas exactly. I'd spray a small spot on a disposable surface and use a small brush from there.
/ Kubota Touch Up Paint? #7
Has anyone used Kubota Paint from AgriSupply? They offer a spray can for $3.95. I purchased some "Autumn Crush" from Lowes, but it must be for the older Kubota color, (I got that paint type from some older threads) , and it does not match the color of my BX25.
There are no Tractor Supply outlets nearby, so I will have to order via the internet.
I need some to match my new BX25 tractor (after I make the forks - - I will post some pictures when done).
Ken
/ Kubota Touch Up Paint? #8
Cool. I was thinking Kubota should offer something like this, but I need the gray color more than orange. Getting lots of chips in the front and rear axles, etc. JD offers green and yellow touch up sticks that look like highlighter pens.
I see this site offers Kubota Excavator Blue, but I can't recall any Kubota excavators that weren't orange too.
/ Kubota Touch Up Paint? #9
Newer ...... older...... what years are we talking here. ?
/ Kubota Touch Up Paint? #10
Your dealer should already have small bottles of touch-up paint or he can order them for you.
/ Kubota Touch Up Paint? #11
Right, I just bought a used 2005 BX-23 and I'm wondering if it's the "new" or "old" Kubota orange. I definitely want to touch up some areas.
/ Kubota Touch Up Paint? #12
I'm pretty sure that the old Kubota tractor orange is "way" older than your BX23. You will love the tractor and be totally amazed at what it can do for you. Congratulations on the BX23!
/ Kubota Touch Up Paint? #13
Ok, that makes sense, thanks. So far I've just played around with it and today removed the cutting deck for winter snow handling service. I'm so far very impressed with how well engineered and SOLID the thing seems, and it starts and runs extremely well, despite being "not new". Once I understood how to remove the deck it was clear that I was NOT picking this thing up! Glad it rolled right out and stored easily, albeit flat.
/ Kubota Touch Up Paint? #14
Good luck on finding Kubota 'New" touch up paint. I had been thinking that I'd buy a quart of paint matching my '09 Kubota to spray paint my implements. Ha! No suck luck. Even Sherwin Williams couldn't match the new orange color. That shocked me - I thought S/W could match ANY paint. Just ain't so though.
Lonestar Panel 24ft. Free Standing Panel with Feed Bunk (A65640)
Lonestar Panel...
2018 FORD F-350 (A65643)
2018 FORD F-350...
2019 Takeuchi TL8 Track Loader with 72in Tooth Bucket (A63689)
2019 Takeuchi TL8...
200 gal Poly Tank (A66408)
200 gal Poly Tank...
Metal Hog Feeder (A65640)
Metal Hog Feeder...
Mini Universal Forks (A65640)
Mini Universal...
