Kubota SVL75 float switch
/ Kubota SVL75 float switch #1
ryanengen
I just purchased a used Kubota SVL75 with about 100 hours on it. the float switch button on my right hand works intermittently. It has come on and worked a few times but doesn't work the majority of the time. is it user error? do I need to have the bucket in a certain position or something? If its broken any other ideas of a fuse or something I can check?
any help would be appreciated.
Thanks!
Ryan
/ Kubota SVL75 float switch #2
You pull the trigger on the right joystick as you push the stick forward.
D.
/ Kubota SVL75 float switch #3
Pull the trigger on the right while you are pushing the stick forward. Takes a little practice.
D.
Ingersoll Rand 185 Air Compressor (A62679)
Ingersoll Rand 185...
3 Point Boom Lift (A62613)
3 Point Boom Lift...
2016 Ford F-150 4wd 4 Door (A63689)
2016 Ford F-150...
John Deere 2032R Loader Tractor (A66285)
John Deere 2032R...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2025 Polaris Ranger XP1000 (A60462)
2025 Polaris...
