Kubota RTV500 HELP PLEASE!!!
/ Kubota RTV500 HELP PLEASE!!! #1
tmtyler
kubota rtv500
I borrowed this RTV from my boss and got it stuck, when we got it unstuck from the mud it was stuck in reverse...I can not bring it back to him stuck, please help!!!:confused:
/ Kubota RTV500 HELP PLEASE!!! #2
With the engine at idle speed, depress the brake down firm, very firm and it should shift easily. Also be sure that it isn't in 4 WD, and if it is shift that to 2WD and try again.
It shouldn't be that hard to shift unless something is damaged. If the above advice doesn't work, as you SLOWLY move the selector from reverse, lightly tap the accelerator pedal with slight pressure on the gear shift selector and then release the accelerator pedal. Be sure to not advance the throttle much, only very slightly.
Hope these work for you, and please report back with your results.
Thank you so much for your help! We had to try it a few times, but it finally worked! You are a life saver!:thumbsup:
/ Kubota RTV500 HELP PLEASE!!! #4
Glad to be of assistance.
Hope you cleaned it up before taking it back to the boss ! :thumbsup:
