Kubota RTV Specific Mods
   / Kubota RTV Specific Mods #11
Mine doesn't have a backup beeber. Can you give me an approximate location where the unused harness might be?
If you have any part numbers that would really be appreciated.
The 1100C comes wired ready for the backup beeper - if you did not order the beeper the connector will be hidden under electrical tape (probably blue) just above the bracket on which the beeper would be installed. I used this bracket to mount the lamp. This is a bit difficult to photograph, but the attached may help. The bracket for my lamp is one I made and it is bolted to the factory beeper bracket which is part of the frame. Hope this helps.
   / Kubota RTV Specific Mods #12
The 1100C comes wired ready for the backup beeper - if you did not order the beeper the connector will be hidden under electrical tape (probably blue) just above the bracket on which the beeper would be installed. I used this bracket to mount the lamp. This is a bit difficult to photograph, but he attached may help. The bracket for my lamp is one I made and it is bolted to the factory beeper bracket which is part of the frame. Hope this helps.
I should certainly give me direction to look. There are 2 connectors back there. One is live with the key on. It is on the right side. The other is on a short connector attached near a sensor on the back of the transmission. I'll search around some more. Thanks for the tip
   / Kubota RTV Specific Mods #13
If I remember correctly- the one that is on with the key is the one that works with the backup light. The switch that will be installed on the transmission makes and breaks the ground.
   / Kubota RTV Specific Mods #14
Interesting that it would run ignition switched hot then make or break ground with another switch to turn on the light. But on the other hand, it would give you a constant hot from ignition switch for another use. Kubota seems to do things just a little different,,,,,, thanks!
   / Kubota RTV Specific Mods #15
My RTV900 had the plastic roof, glass windshield, plastic bed liner, speedo, under hood storage box, hand throttle, front receiver hitch, and road light kit. I also fabbed up a ROPs grab handle for the driver side like there was for the passenger side. (y)
   / Kubota RTV Specific Mods #16
Interesting to hear you guys adding back up beepers. I always remove them right away.
   / Kubota RTV Specific Mods #19
I didn't see anything about back up beebers, just back up lights
Oh, i should read more carefully..... backup lights wired to the beeper circuit is entirely different, and very useful. thanks for the correction.
   / Kubota RTV Specific Mods #20
Here's what I have on the tail end.
(2) ROLLING STANDS (A58374)
(2) ROLLING STANDS...
2021 ASV RT-120F FORESTRY SKID STEER (A52709)
2021 ASV RT-120F...
2012 MACK CHU613 (A58214)
2012 MACK CHU613...
2013 Chrysler Town and Country (A56859)
2013 Chrysler Town...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A56436)
2023 New Holland...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
