Kubota RCK60B23BX MOWER
/ Kubota RCK60B23BX MOWER #1
Daryl
Southwest Virginia
New Holland TC30,, Kubota Bx2360
I have this mower on a bx2360. I need some blades and when i go to web sites like Messick's it list a lot of different part numbers. I have read and cannot figure out what the difference is or which one to order. Even gator blades wouldbe fine but read where you need to use shims or something to make them work. I just want to bolt them on. Does anyone know which ones to order. Messicks list: Kubota K5371-97520 Blade Kit (3 Blades) or K5371-99040 or K5371-34340.... Are there differences of some kind. Prices are different.
Thanks Daryl
/ Kubota RCK60B23BX MOWER #2
It is my understanding, that you need to use the serial number on your deck. That will get you the exact fit.:2cents:
Thank You. I will try that...
/ Kubota RCK60B23BX MOWER #4
There are gator blades that work now without shims. They just came out last spring for the Kubota 60" deck.
They are the 3-1 mulching blades. I posted some picks in the forum last spring with part numbers. They work great, better than the OEM blades. I highly recommend them.
/ Kubota RCK60B23BX MOWER #5
Your 34340 is the blade that should fit. Beware the kit prices are more! We have found that the gator blades are not compareable steel and will wear out faster then the standard Kubota blade. That is what we have been told by our pro mowers any way.
I found that out on kit blades. Does not make sense. Thank you .. I will check on the 34340 blades.
20 Yard Dumper (A61166)
20 Yard Dumper...
1998 Ford L9501 Louisville 101 Truck, VIN # 1FTYN90K4WVA35579 (A61165)
1998 Ford L9501...
207269 (A52708)
207269 (A52708)
211299 (A62131)
211299 (A62131)
207276 (A52708)
207276 (A52708)
Skid steer Asphalt attachment (A61567)
Skid steer Asphalt...
