Kubota pin-type QA?
/ Kubota pin-type QA? #21
New QA forks on my 3540.
/ Kubota pin-type QA? #22
I have a Kubota B7610 with an LA 352 loader... I wanted to purchase a Curtis Snowpusher, however It requires having a skid steer attachment on my loader. I have the pin type. Is it possible when I remove the pins that hold my bucket on to put on an attachment(where the pins are) that would allow me to accept skid steer attachments? I understand that my bucke would then become obsolete with the skid steer attachement in place?
/ Kubota pin-type QA? #23
Curtis also sells pin-on mounts that match up with at least some of the manufacturers loaders. You probably need to contact them to see if they have a pin-on mount for your loader model.
ATI makes a light duty skid steer type QA, but again, you'd need to check with them to see if they have one for your loader, because they also make pin-type QAs for the lighter duty loaders.
/ Kubota pin-type QA? #24
I assume you are talking about a plow when you say snowpusher? Having owned/operated several B series machines in my business, the B series are too small for snowpushers. Heck, i wouldnt even put a pusher on my grand L 40.
/ Kubota pin-type QA? #25
I would have to say that you do not know your L 40 very well then. I had a 7'6" on my L3830 for 5 years with no problems.
/ Kubota pin-type QA? #26
Those pictures are plows, not pushers. Im fine with plows, box blades or pushers is another story.
/ Kubota pin-type QA? #27
Must be a word thing. What's the difference between a pusher and a plow?
Is a pusher just a straight blade?
jb
/ Kubota pin-type QA? #28
a pusher is like a straight blade with sides that come foward, it looks sort of like a box blade mounted on a loader... here is an example:
they are often used to clear parking lots as they keep the snow in and let you just "push" it across the lot.
that one is made by Pro-Tech (Winter Products Corp- Pro-Tech Products)
Aaron Z
/ Kubota pin-type QA? #29
OK, I've seen that, but mostly on larger end loaders.
jb
Morbark M12D Wood Chipper (A63689)
Morbark M12D Wood...
John Deere Lift Arms (A65640)
John Deere Lift...
STIHL FS80R POLE SAW (A64276)
STIHL FS80R POLE...
2000 Chevrolet Express 1500 Conversion Van (A66408)
2000 Chevrolet...
2022 EZ-GO ELITE...
Grace Quick Attach Tree Puller (A66408)
Grace Quick Attach...
