Kubota M9540
/ Kubota M9540 #1
DT86
Elite Member
VA
Kubota
The man I put up hay for has a M9540 just like mine but a little older. It has about 800 hours on it, hydro shuttle and 12 speed.
The hand throttle pushed all the way forward will not go above ~500 PTO RPM's. This is a major PITA as you can imagine.
I know this tractor has been split early on in it's life due to a faulty clutch pack and assume the throttle linkage wasn't set back properly.
Where can I adjust the linkage?
/ Kubota M9540
Anyone?
/ Kubota M9540 #3
/ Kubota M9540 #4
Does the foot throttle allow it to go higher?
/ Kubota M9540
Yes the foot throttle works just fine.
/ Kubota M9540 #6
Not sure about the older models and I am assuming you are talking about a cab M9540...
On mine the hand throttle lever operates a cable that pulls down on the foot throttle.
The adjustment is on the hand lever under the cowling.
/ Kubota M9540
Well by older I mean a year or two, they all should be the same. It is actually a platform tractor but the linkage should also be the same I would think.
Do you mean right under the leaver?
/ Kubota M9540 #8
Sorry, open-station will have completely different linkage.
"aczlan" above has the best advice.
The hand lever adjustment should be at the bottom end of its connection.
/ Kubota M9540
So you all mean right at the injector pump.
Is it just me or does the hood not open far enough to get to anything? Especially with the loader in the way too!!
2002 Built Rite Trailer (A66285)
2002 Built Rite...
Wacker Neuson AR14H (A60462)
Wacker Neuson...
2010 Ford F750 Single Axle Dump (A62613)
2010 Ford F750...
New/Unused 72in No Till Seed Drill (A65583)
New/Unused 72in No...
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A65053)
2018 JOHN DEERE...
NEW ATA-EPC40 Plasma Cutter (A62679)
NEW ATA-EPC40...
