Kubota M7040 & Moldboard Plow
   / Kubota M7040 & Moldboard Plow #1
downslope
Platinum Member
NY
MF TO-35, Ford(s) 2000, 8N, 9N, White 2-70, NH TD75D, JD 5045D
Will I be able to handle a 3x16" JD 3-point moldboard plow with a 7040?
It would be on level ground, easy soil conditions.
   / Kubota M7040 & Moldboard Plow #2
My uncle used a 3-16 plow for over 30 years in clay soil behind a 50hp 2wd tractor with no problem. My guess is a 7040 4wd with ballasted rear tires would have no problem with a 3-16 plow in easy soil.
   / Kubota M7040 & Moldboard Plow #3
I would say, it will handle it just fine.
   / Kubota M7040 & Moldboard Plow #4
I pull a three bottom with my M 6800 easily. You will have no problem at all.
   / Kubota M7040 & Moldboard Plow #5
R-1 or Ag tires?
I know that :), but does he have these tires and not R-4's. Can't plow with R-4's.
No, it is R-1's, 16.9x30.
I was asking the question because the M7040 seems a little lighter weight and smaller engine (203 cid and no turbo) than a 70hp tractor I owned in the past. I THINK if I weight it up it should be OK. I'm also assuming that if I make the tread width as wide as possible the plow will track properly.
   / Kubota M7040 & Moldboard Plow #9
Good on the tires.
I'd suggest first setting the plow up to track straight away behind the tractor, then set the furrow wheel at the right position. Land wheel can be set the same from center.
How soon are you going to try this out?
   / Kubota M7040 & Moldboard Plow #10
We've pulled a JD 1600 moldboard plow (3x16) with our JD 2550 (2wd) for years. Its a little bigger tractor than a M7040 as it weighs about 10,000lbs fully ballasted and is 65 PTO hp. In tough yellow clay that plow is all that tractor can handle. However, I assume yours is 4wd, and based on your soil you shouldn't have any trouble. As mentioned above, you'll need to set your front and rear tread width properly which should be in the plow manual, I can't recall the proper width off the top of my head.
2009 Chevrolet Traverse LS SUV (A51694)
2009 Chevrolet...
Kivel Pallet Forks (A50121)
Kivel Pallet Forks...
2025 Swict 66in Bucket Skid Steer Attachment (A50322)
2025 Swict 66in...
2003 GMC 3500 Ambulance (NOT RUNNING)(NO TITLE) (A50774)
2003 GMC 3500...
2006 Deere 410G (A50120)
2006 Deere 410G...
