Kubota M6800 shuttle grinding
   / Kubota M6800 shuttle grinding #1
awhite
Southwest Virginia
Kubota M6800/Kubota L3830/MKubota M8560 CAB/Kubota ZD221/Kubota BX1500/Ford 3930
We've got a Kubota M6800 with a dry clutch which we had to replace last winter. It has been working fine until about a couple of weeks ago. Now when "shuttling" between F/R, there's a grinding noise when trying to go into R. The clutch is adjusted within specs. Not sure if there's a sync problem or if maybe the throwout bearing isn't fully disengaging. Figured we'll have to split it either way. Any suggestions appreciated!
   / Kubota M6800 shuttle grinding #2
I once owned a M4900 that acted similar to what you describe. Then one day it locked in reverse. Long.story short story I had to split tractor & R&R reverser assembly. My tractor had been used quite a bit handling 18 wheeler loads of rd bales.
Thanks for the reply!
The reverser assembly you're referring to, is it the shuttle gear case that's depicted in this blowout:
Kubota M68DT / M68SDT (Dual traction 4wd / Rops) Parts Diagrams
If so, it looks like it's accessible by just splitting the clutch housing from the engine. I was hoping that's all I would have to do. But kinda figured I would have to split the transmission also.
   / Kubota M6800 shuttle grinding #4
You're correct. My tractor was split between engine & clutch housing to R&R synchronizer assembly.
Thanks again!
Did you have replace the whole assembly or are you able to repair parts that are inside of the assembly?
   / Kubota M6800 shuttle grinding #6
I replaced the syncro pack not the complete unit.
   / Kubota M6800 shuttle grinding #8
It's been several yrs since I repaired the shuttle but I think I had to replace the syncro assembly(key 110)
Thanks!!
Maverick 3250 Excavator Hammer (A50774)
Maverick 3250...
1991 Peterbilt 378 T/A Dump Truck (A50323)
1991 Peterbilt 378...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2011 Manac 36245B30 45ft T/A Walking Floor Trailer (A50323)
2011 Manac...
2008 CATERPILLAR 304C CR EXCAVATOR (A51406)
2008 CATERPILLAR...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
