Kubota M6800 shuttle grinding
   / Kubota M6800 shuttle grinding #1
awhite
Southwest Virginia
Kubota M6800/Kubota L3830/MKubota M8560 CAB/Kubota ZD221/Kubota BX1500/Ford 3930
We've got a Kubota M6800 with a dry clutch which we had to replace last winter. It has been working fine until about a couple of weeks ago. Now when "shuttling" between F/R, there's a grinding noise when trying to go into R. The clutch is adjusted within specs. Not sure if there's a sync problem or if maybe the throwout bearing isn't fully disengaging. Figured we'll have to split it either way. Any suggestions appreciated!
   / Kubota M6800 shuttle grinding #2
I once owned a M4900 that acted similar to what you describe. Then one day it locked in reverse. Long.story short story I had to split tractor & R&R reverser assembly. My tractor had been used quite a bit handling 18 wheeler loads of rd bales.
Thanks for the reply!
The reverser assembly you're referring to, is it the shuttle gear case that's depicted in this blowout:
Kubota M68DT / M68SDT (Dual traction 4wd / Rops) Parts Diagrams
If so, it looks like it's accessible by just splitting the clutch housing from the engine. I was hoping that's all I would have to do. But kinda figured I would have to split the transmission also.
   / Kubota M6800 shuttle grinding #4
You're correct. My tractor was split between engine & clutch housing to R&R synchronizer assembly.
Thanks again!
Did you have replace the whole assembly or are you able to repair parts that are inside of the assembly?
   / Kubota M6800 shuttle grinding #6
I replaced the syncro pack not the complete unit.
   / Kubota M6800 shuttle grinding #8
It's been several yrs since I repaired the shuttle but I think I had to replace the syncro assembly(key 110)
Thanks!!
2025 Swict 72in Bucket Skid Steer Attachment (A50322)
2025 Swict 72in...
2013 VOLVO VNM TANDEM AXLE DAY CAB (A52141)
2013 VOLVO VNM...
Alamo SH88 88" 3pt Flail Mower (A50774)
Alamo SH88 88" 3pt...
1000 Gallon Concrete Fuel Tank (A50774)
1000 Gallon...
2020 International MV607 2,000 Gallon Water Truck (A50323)
2020 International...
Mower King Q.A Pallet Forks (A50121)
Mower King Q.A...
