Kubota M6800 shuttle grinding
   / Kubota M6800 shuttle grinding #1
awhite
Southwest Virginia
Kubota M6800/Kubota L3830/MKubota M8560 CAB/Kubota ZD221/Kubota BX1500/Ford 3930
We've got a Kubota M6800 with a dry clutch which we had to replace last winter. It has been working fine until about a couple of weeks ago. Now when "shuttling" between F/R, there's a grinding noise when trying to go into R. The clutch is adjusted within specs. Not sure if there's a sync problem or if maybe the throwout bearing isn't fully disengaging. Figured we'll have to split it either way. Any suggestions appreciated!
   / Kubota M6800 shuttle grinding #2
I once owned a M4900 that acted similar to what you describe. Then one day it locked in reverse. Long.story short story I had to split tractor & R&R reverser assembly. My tractor had been used quite a bit handling 18 wheeler loads of rd bales.
Thanks for the reply!
The reverser assembly you're referring to, is it the shuttle gear case that's depicted in this blowout:
Kubota M68DT / M68SDT (Dual traction 4wd / Rops) Parts Diagrams
If so, it looks like it's accessible by just splitting the clutch housing from the engine. I was hoping that's all I would have to do. But kinda figured I would have to split the transmission also.
   / Kubota M6800 shuttle grinding #4
You're correct. My tractor was split between engine & clutch housing to R&R synchronizer assembly.
Thanks again!
Did you have replace the whole assembly or are you able to repair parts that are inside of the assembly?
   / Kubota M6800 shuttle grinding #6
I replaced the syncro pack not the complete unit.
   / Kubota M6800 shuttle grinding #8
It's been several yrs since I repaired the shuttle but I think I had to replace the syncro assembly(key 110)
Thanks!!
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A49461)
2014 MultiQuip...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
71069 (A49346)
71069 (A49346)
2020 CATERPILLAR 289D3 SKID STEER (A51242)
2020 CATERPILLAR...
2007 CHEVROLET SILVERADO 4X4  DUALLY TRUCK (A51222)
2007 CHEVROLET...
2016 Ford F-150 Ext. Cab Pickup Truck (A50323)
2016 Ford F-150...
