Kubota M62 Cranks, Won't Start, Backhoe/3PH Interlock Issue (SOLVED!)
   / Kubota M62 Cranks, Won't Start, Backhoe/3PH Interlock Issue (SOLVED!)
Woooo hoooo what team work.... We did it buddy!!!!!! Well done!!!
Your brains, my brawn. I got really lucky when you found my call for help!
PS: I'm sure I'll be reaching out to you when I put on my 3rd function on the back for a thumb, I see you've done it.
Jen
Unlike the top'n'tilt debacle, the thumb on the backhoe was relatively drama free. The foot pedal and the steel lines on the boom were already there, so all that was needed was to connect the cylinder and the thumb and add a couple of rubber lines. Hopefully your M62 has the same parts, but if not, Kubota has a kit.
Having said that, there are some articles here in TBN that list aftermarket sources for the thumb. I didn't do my homework before I saw them, but it sounds like I'd have saved a lot of money and maybe even ended up with a better thumb.
Thanks again for the help. Really saved the week!
   / Kubota M62 Cranks, Won't Start, Backhoe/3PH Interlock Issue (SOLVED!) #12
I have an aftermarket thumb on my Kubota L48.
It was made by M.C. Faulkner & Sons in Buxton, ME.
Faulkner has since been bought out by SRS Attachments of Norridgewok, ME.
The thumb was already mounted when I bought my (used) machine.
I am VERY pleased with their thumb, but have no idea of the cost to the original owner.
For others who might be interested: The SRS phone number is 207-858-0690.
   / Kubota M62 Cranks, Won't Start, Backhoe/3PH Interlock Issue (SOLVED!) #13
Appreciate the successful solution follow up. The M59 has the 3 pt/backhoe valves but not sure of a electrical interlock to prevent starting. The labels on valve positions is about faded out on mine so have extra Paint pen instructions.
   / Kubota M62 Cranks, Won't Start, Backhoe/3PH Interlock Issue (SOLVED!) #14
I'm just glad we were able to figure out what was wrong before you had to call in help (visuals of $$$ signs floating skyward) from the Stealer... (dealer).... and to be honest, what made the difference is that you were not too proud to reach out to the community for help... that's why you got an answer..... :)
PS: It wasn't luck, I was stalking you.. I subbed to your channel ages ago when you pulled that bucket out of the side of your van with your M, pretty impressive... LOL
Jen :)
   / Kubota M62 Cranks, Won't Start, Backhoe/3PH Interlock Issue (SOLVED!) #15
I don't think the M59 has that interlock. You can start the engine with the valves out of position and it lugs.
   / Kubota M62 Cranks, Won't Start, Backhoe/3PH Interlock Issue (SOLVED!) #16
it makes you wonder how many trips have been booked into the shop to resolves this resulting in service work, service calls or hey while you're here why don't we etc etc etc...
I was thinking about that earlier this morning, too. Unless the mechanics were familiar with the Kubota M62 and this particular issue, they'd probably spend a LOT of time stumbling around, checking other safety interlocks, basic component function, and replacing perfectly good parts. All on the customer's dime if, as in my situation, the warranty is long expired.
In the past I've had good luck talking to mechanics at the dealership about mechanical issues. The lead mechanic at the dealer where I purchased my top'n'tilt and thumb upgrades from was very helpful, first with trying to solve the leaky spool issue, then recalibrating the auto level on the FEL. The mechanic at another dealership walked me through replacing a seal buried deep inside the transmission on the old Kubota. That's the direction I was headed if you hadn't come to the rescue, Jen.
But I also have a theory that I'm hardly ever the first person to stumble into any particular problem, and somebody out there has the answer. Google is great if someone has documented their experience somewhere, and when that doesn't work, forums like TBN make it very easy to reach out. I gave Google a good workout Monday when the problem first started, but was still coming up empty handed Tuesday afternoon. That tells me that the interlock issue isn't wide spread, likely because not a lot of M62s are out there, and most of the owners don't even install the 3PH. I hate having to ask for help (yeah, it is a guy thing šŸ˜„) but I have no qualms about doing so if I've made a good effort to solve my own problem first. At least to the point where I can ask the right questions. There were at least two things going on, and the regen turned out to be a red herring. And the solution would only have been found by someone using the 3PH stuff, and we're rare birds, Jen. Maybe I should buy a lottery ticket this week when I go into town? Or maybe I should lay low for a while, having used up a huge portion of my Karma?:rolleyes:
When you connected the backhoe hoses did you also change the two valves under the seat? Tractor deadheading the hydraulics?
Rereading your post, SD, that was essentially the problem, but in reverse. I had the hoses hooked up, but then had to disconnect them to better align the tractor when the hoe shifted on the gravel pad. The levers were in the backhoe position by then, so the tractor wouldn't start because of the interlock. But it did start a time or two after it sat overnight, likely because enough hydraulic pressure had leaked off that it took a few seconds for the interlock to kick in. I'm lucky something else didn't break under all that pressure, and that Kubota put a heck of a starter into these tractors!
BTW, I've updated the topic of this thread to reflect the actual issue. Hopefully that will make it easier for someone else to solve the same problem.
   / Kubota M62 Cranks, Won't Start, Backhoe/3PH Interlock Issue (SOLVED!) #20
I think maybe you should just hook up a charger to the battery, crack a beer, get up in the seat and just spend 15 minutes or so turning it over repeatedly to enjoy the sound of it firing up.. LOL
2012 NISSAN 110 FORKLIFT (A55745)
2012 NISSAN 110...
2011 TOYOTA Prius (A56859)
2011 TOYOTA Prius...
2022 BOBCAT E60 R2-SERIES EXCAVATOR (A52709)
2022 BOBCAT E60...
2019 International DuraStar 4300 24FT Box Truck (A56858)
2019 International...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
