Kubota M6040HD
/ Kubota M6040HD #1
makemeglo
Kubota M6040HD
HELP !!!
Tractor will run for about 1/2 hour and then shuts off ~ then starts back up runs about 5 seconds and shuts off ~ if let set it will run again for another 1/2 hour and shut off again
/ Kubota M6040HD #2
I'm not familiar with that tractor, but the symptoms are consistent with fuel restriction. Plugged filter(s)? plugged fuel line? trash in tank/lines?
If you take the first fuel filter off, does fuel run out of the line?
/ Kubota M6040HD
Haven't taken any fuel lines off yet ~ but did empty the water separator cylinder and when we started it up again it filled to the empty cylinder line
thanks
glo
/ Kubota M6040HD #4
bad wire causing the pump shut off to activate?
defective ignition switch?
/ Kubota M6040HD #5
If all else fails, check the vent on the fuel cap.
E/S
BOSCH BULLDOG XTREME ELECT. HAMMER DRILL (A62131)
BOSCH BULLDOG...
(96) 1"X8"X10" PONDEROSA PINE BOARDS (A62131)
(96) 1"X8"X10"...
Snap-On Southern Thunder Edition 24-drawer tool box (A63118)
Snap-On Southern...
159120 (A60430)
159120 (A60430)
2020 Steiner 450 Slope Mower (A61166)
2020 Steiner 450...
17601CFL (A59228)
17601CFL (A59228)
