Kubota M5700 3 point hitch wont go up
   / Kubota M5700 3 point hitch wont go up #1
az6930
Kubota M5700
I recently replaced a hose on the control valve and when I started it back up the 3 point wont raise. When I leave the 3 point hitch lever in the lift position and curl the bucket it will raise. Is air in the system? Any help would be appreciated.
   / Kubota M5700 3 point hitch wont go up #2
Put a gage in the system and check your pressure.
On the control valve(joystick valve) I see the four line that run to my bucket and loader arm cylinders. There are 3 more lines on the valve one is labeled P, one is T, and one is BY. I assume that P is pump pressure, T is tank and BY goes to my 3 point. Does this sound right?
   / Kubota M5700 3 point hitch wont go up #4
Sounds like you might have the tank and power beyond lines swapped.
   / Kubota M5700 3 point hitch wont go up #5
Yes, that is 100% correct. The BY stand for "beyond" or "power beyond", it job is to feed the next valve in the sreies-in your case the 3PH which is most common. What line did you replace? Did you have only the one disconnected?
2016 Kubota RTV-X900 4x4 Utility Cart (A51691)
2016 Kubota...
23169 (A50324)
23169 (A50324)
2016 Autocar Xpeditor Garbage Truck (A51692)
2016 Autocar...
2010 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2010 Ford F-150...
2018 KOMATSU PC360LC-11 EXCAVATOR (A51246)
2018 KOMATSU...
2015 Ottawa Yard Spotter Truck - Cummins Diesel, Allison 6-Speed, Hydraulic Air Fifth Wheel (A52748)
2015 Ottawa Yard...
