Kubota M5700 3 point hitch wont go up
   / Kubota M5700 3 point hitch wont go up #1
az6930
Kubota M5700
I recently replaced a hose on the control valve and when I started it back up the 3 point wont raise. When I leave the 3 point hitch lever in the lift position and curl the bucket it will raise. Is air in the system? Any help would be appreciated.
   / Kubota M5700 3 point hitch wont go up #2
Put a gage in the system and check your pressure.
On the control valve(joystick valve) I see the four line that run to my bucket and loader arm cylinders. There are 3 more lines on the valve one is labeled P, one is T, and one is BY. I assume that P is pump pressure, T is tank and BY goes to my 3 point. Does this sound right?
   / Kubota M5700 3 point hitch wont go up #4
Sounds like you might have the tank and power beyond lines swapped.
   / Kubota M5700 3 point hitch wont go up #5
Yes, that is 100% correct. The BY stand for "beyond" or "power beyond", it job is to feed the next valve in the sreies-in your case the 3PH which is most common. What line did you replace? Did you have only the one disconnected?
2025 ZWB 59in Excavator Boom Mini Skid Steer Attachment (A56857)
2025 ZWB 59in...
2014 John Deere 850K LGP Crawler Dozer (A59213)
2014 John Deere...
IRGC40 High-End Mini Golf Cart (A57149)
IRGC40 High-End...
1605 (A57192)
1605 (A57192)
2018 Ford Explorer AWD SUV (A56859)
2018 Ford Explorer...
2330 (A58376)
2330 (A58376)
