Kubota M5700 3 point hitch wont go up
   / Kubota M5700 3 point hitch wont go up #1
az6930
Kubota M5700
I recently replaced a hose on the control valve and when I started it back up the 3 point wont raise. When I leave the 3 point hitch lever in the lift position and curl the bucket it will raise. Is air in the system? Any help would be appreciated.
   / Kubota M5700 3 point hitch wont go up #2
Put a gage in the system and check your pressure.
On the control valve(joystick valve) I see the four line that run to my bucket and loader arm cylinders. There are 3 more lines on the valve one is labeled P, one is T, and one is BY. I assume that P is pump pressure, T is tank and BY goes to my 3 point. Does this sound right?
   / Kubota M5700 3 point hitch wont go up #4
Sounds like you might have the tank and power beyond lines swapped.
   / Kubota M5700 3 point hitch wont go up #5
Yes, that is 100% correct. The BY stand for "beyond" or "power beyond", it job is to feed the next valve in the sreies-in your case the 3PH which is most common. What line did you replace? Did you have only the one disconnected?
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
UNUSED FUTURE SKID STEER QUICK ATTACH TRENCHER (A51244)
UNUSED FUTURE SKID...
UNUSED FUTURE MINI EXCAVATOR HYD 18" AUGER (A51244)
UNUSED FUTURE MINI...
2015 CATERPILLAR AP1055F ASPHALT PAVER (A51242)
2015 CATERPILLAR...
2011 Volvo Semi Truck (NOT RUNNING) (A50774)
2011 Volvo Semi...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
