Kubota M4D-071HDC12-D
   / Kubota M4D-071HDC12-D #11
Why not go with the M7060. Essentially same tractor with different transmission and proven reliability. There are very few differences unless you have to have a buddy seat or a couple of other small items. It actually has slightly more PTO HP. Took 5 months though for my new one to get here but I custom ordered with a lot of options.
   / Kubota M4D-071HDC12-D #12
That's what I'd recommend^
Or an M5. I really should have gone with an M5 but I limited myself to my ability to transport it with the equipment I had at the time and the M4 maxed me out.
   / Kubota M4D-071HDC12-D #14
For me the creeper gear is a must have, but it doesn't appear to be offered on the M7060. I would think for many people the M7060 would be a great alternative.
It has the option for a creeper gear. Mine brand new one has it. And it's cheaper than the creeper gear for the M4D by a few hundred dollars.
This is exactly what I ordered.
> M7060HDC12 - 4WD TRACTOR W/12 SPEED HYDRAULIC SHUTTLE & CAB
> FRONT LSW320/70R24 GDYR R14T
> REAR LSW420/75R34 GDYR R14T
> 1 2ND POSITION LEVER KIT
> HYDRAULIC FLOAT DETENT (FD)
> 1 REAR WINDOW WIPER KIT W/WASHER
> 1 3RD FUNCTION VALVE KIT CAB
> 1 FRONT LOADER (2 LEVER TYPE QUICK COUPLER)
> 1 HIGH CAPACITY ALTERNATOR KIT
> 1 AIR RIDE SEAT SUSPENSION UPGRADE KIT
> 1 AIR RIDE SEAT WIRE HARNESS
> 1 STANDARD VALVE KIT FOR CAB
> 1 CREEP SPEED KIT
   / Kubota M4D-071HDC12-D #15
By now I'm getting confused about the differences between the M4 and M5, M6000 & M7060. Why so many models? Are the differences significant? I'm missing something here.
rScotty
M59
   / Kubota M4D-071HDC12-D #16
rScotty
M59
M4 is the deluxe version of the 7060, all the bells and whistles. Think of the 7060 as a F250 and the M4 is the King Ranch edition, gives up a few PTO HP as trade off.
M5 is the next step up for engine size.
M6000 and 7060 are just different engines.
   / Kubota M4D-071HDC12-D #17
Thanks. That makes sense.
rScotty
thankfully our F250 doesn't read TBN.
   / Kubota M4D-071HDC12-D #18
> 1 CREEP SPEED KIT
That's good to hear that a creep range is available. Could you post the speeds in creep range? Can you use the creep for all 12 gears?
   / Kubota M4D-071HDC12-D #19
I was able to find a pdf of the operators manual that gives the speeds. Here's a screenshot for anyone else who might be interested.
UNUSED FUTURE D-PDQ 47" LAND LEVELER (A52706)
UNUSED FUTURE...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
MULTIQUIP WHISPERWATT MQ POWER 25 GENERATOR (A52706)
MULTIQUIP...
2023 Kubota M4-061 Deluxe MFWD Utility Tractor with LA1154 Front Loader (A55314)
2023 Kubota M4-061...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
