Kubota M 9540 problem
   / Kubota M 9540 problem #1
buddy in burlington
burlington
Kobota M9540
After working my Kubota M9540 an hour or so, it sounds like something internally is out of balance....like a rod knocking but it is coming from the transmission area. It has a manual shuttle shift transmission and sometimes is hard to shift from forward to reverse and vice versa. Sometimes I have to rock the tractor back and forth with the clutch to get it to shift. Any ideas or suggestions?
   / Kubota M 9540 problem #2
If your tractor has a Lot of hours, the shifter forks could be worn to the point they do not fully engage & disengage...
If it has lower hours, I would suspect a bent fork... KennyV
Kubota BX25D (A53317)
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
FORD F550 SUPER DUTY SERVICE TRUCK (A52707)
FORD F550 SUPER...
2012 BIG TEX PIPE TRAILER (A58214)
2012 BIG TEX PIPE...
2018 Chevy Traverse 3rd Row Seating (A56436)
2018 Chevy...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
