Kubota Loader Detent Kit - Help!
   / Kubota Loader Detent Kit - Help!
So I tried a couple different spring/detent configuration. I first tried leejohn's method, putting the spring and then the big ball above the detents. There was too much pressure on the detents and no way to hold everything in place while slipping the cap over the assembly. I then tried putting the spring on the bottom and the big ball right below the detents. This didnt work either.
I did notice the stiffness goes out of the joystick when i remove the detent assembly, so my problem is definitely in the spring/detent/ball configuration.
   / Kubota Loader Detent Kit - Help! #12
Getting the sleeve over the small balls when the big ball is pushing out is going be tricky, but after getting it over then you put the end cap on. Is that the way you tried? The big ball has to push on the small ones and with total movement of the spool there would have to be something holding the ball and spring in place. The small balls roll as they move back and forth in the sleeve and they can't if the spring is between them. Also the sleeve and end cap can't go on at the same time. When you took it apart the balls should of went flying unless you were ready to catch them.
When I took it apart the first time, the large ball and spring were sitting in the bottom of the cap, and the small detents were in their proper place. My assumption, based on what I saw and Kubota's shoddy diagrams were that the spring being centered in the sleeve, behind the detents, was holding the detents from falling inwards. What I didn't understand was how the spring was going to stay centered on the large ball. What I saw when I took it apart looked like this:
If I understand you correctly, you think it should look like this:
I tried to install it with the large ball above the detents, but the spring was so compressed that I had trouble keeping the detents in place - they wanted to shoot all over the place. I think the only way to make that configuration work would be to hold the large ball in place with something long and thin (like a drift pin), install the cap (without the bottom piece) over the sleeve and drift pin, then try to slip the bottom plate into place and install the spring clip. Does that sound right?
   / Kubota Loader Detent Kit - Help! #14
Yes that is what I thinking it should go. That also is the way I was thinking to put it together.
I'll give 'er a try this weekend and let you know how it goes. Thanks for the input!
Well a minor victory and setback. Got everything installed correctly (large ball above the detent) and no stiffness in the joystick and it clicks into float! However when i pull back on the joystick (lifting the bucket) the joystick still isnt returning to neutral and the bucket keeps lifting. I dont have this problem lowering the bucket. Also the tractor womt stay in float. It clicks in but the minute i let go of the joystick it jumps out of float. The joystick literally springs back to the neutral position from the forward (lowering) position.
Any ideas? My next attempt (barring any ideas from you folks) will be to reuse the old internals and see if that helps.
   / Kubota Loader Detent Kit - Help! #17
Does it seem to ok with the tractor not running? If so, then I would 1st guess the spool and float are not screwed together tight.
Does the same thing whether the tractor is running or not.
Ok slowly but surely I am getting there. I had an o-ring in a spot where i didn't need one (tried using one that was leftover in the rebid kit in the wrong place). Little egg on my face, but with that removed the joystick now acts like it should - free moving and jumps back to neutral. However I still cant figure out the detents for float. It definitely clicks into float, but won't stay there - it pops right back into neutral when i let go of the joystick.
Any ideas? I thought about backing the sleeve out of the spool a little bit to see if the extra length pushing downwards would help, but it feels like the detent balls are grabbing pretty good, so I don't think that would help? And the sleeve was screwed in tight to the spool before (although the prior configuration was wrong, so maybe the previous owner messed stuff up and overtightened it?)
   / Kubota Loader Detent Kit - Help! #20
The small balls have to line up with grove in the sleeve. Can you just pull the cap off and maybe see where they are in the sleeve when pushed into float? Then you also might be able to screw the sleeve in or out like you thought about doing. That should tell you something.
Before you do that make sure the spool is moving the same in and out. Try pushing the spool in by hand without being hooked to the joystick
New/Unused 84in Quick Attach Rock Bucket (A51573)
New/Unused 84in...
2013 International DuraStar 4400 Service Truck with Crane, VIN # 3HAMKAAN2DL270086 (A51573)
2013 International...
2019 Ford E-450 Super Duty Passenger Bus (A51692)
2019 Ford E-450...
New/Unused 48in Quick Attach Pallet Forks (A51573)
New/Unused 48in...
John Deere MX 8 Brush Hog, 8', 3pt Hook Up, PTO  (A52384)
John Deere MX 8...
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
