Kubota, Leaky fitting, anyone familiar with this one?
   / Kubota, Leaky fitting, anyone familiar with this one? #11
Good Job - that lip is only 1/16" if that to grip on - glad you were able to get it loose with a torx bit! The Kubota orings are usually black and you should not need a lot of torque to seal with a new oring/plug.
Keep us posted on progress and new plugs.
Thanks. I may have got it loose with the torx, but not out, as the torx broke almost immediately. After moving the hoses out of the way, could get a better grip with the long nose vise grips. Be a couple of days before I get the parts.
Odd someone would not have spend the 10 bucks or so for the Kubota part and opt to do a bodge job on it.
   / Kubota, Leaky fitting, anyone familiar with this one? #13
If all it needs is an oring.....that can be had at a local hydraulic shop same day.....
It's odd to me that someone would spend $10 and still have to wait a few days
Oh, I have a small stock of ORB type orings. I've gotten them from Summit and Discount when I've ordered other parts from them.
The cap/plug itself is now so buggered up I don't want to use it.
The hex (for an allan wrench) was rounded out by someone before me and is now filled with the remains of a torx I tried. The vise grip used to get it out pretty much uglified the circumference of the plug.
Given that, I would not feel confident of getting it ever on securely let alone every getting it off again. Also, there's gotta a be a reason it apparently blew out once before. I'm just hoping it is the plug itself and not the cylinder. I guess the factory oring could have failed initially and the "other guy" used one not rated for hydraulics.
I got the order in too late to ship yesterday, so ships today, maybe get it Friday or Saturday.
   / Kubota, Leaky fitting, anyone familiar with this one? #15
Managed to get a torx in there after moving the cross over hoses away, but it broke immediately. Chinesium bit, hollow apparently. Odd.
Finally got it out with a long nose vise grip after much coaxing. The seal is definitely blown out and is not a black oring but kind of yellow green, almost like ac (freon) oring. Certainly not going to use that plug again, so, I'll just order up a couple plugs with seals. I hope. It's only money.
Sounds like you used a tamper proof torx bit.
Yep. Only one I had that could fit in the hole. Still, not much force was applied.
1994 Peterbilt 379 Semi (A50514)
1994 Peterbilt 379...
Woods 3180 Batwing Mower (A50514)
Woods 3180 Batwing...
1986 VIM TACK TANKER TRAILER (A50854)
1986 VIM TACK...
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
2006 Peterbilt 379 T/A Wet Kit Sleeper Cab Truck Tractor (A49461)
2006 Peterbilt 379...
