Kubota, Leaky fitting, anyone familiar with this one?
   / Kubota, Leaky fitting, anyone familiar with this one? #11
Good Job - that lip is only 1/16" if that to grip on - glad you were able to get it loose with a torx bit! The Kubota orings are usually black and you should not need a lot of torque to seal with a new oring/plug.
Keep us posted on progress and new plugs.
Thanks. I may have got it loose with the torx, but not out, as the torx broke almost immediately. After moving the hoses out of the way, could get a better grip with the long nose vise grips. Be a couple of days before I get the parts.
Odd someone would not have spend the 10 bucks or so for the Kubota part and opt to do a bodge job on it.
   / Kubota, Leaky fitting, anyone familiar with this one? #13
If all it needs is an oring.....that can be had at a local hydraulic shop same day.....
It's odd to me that someone would spend $10 and still have to wait a few days
Oh, I have a small stock of ORB type orings. I've gotten them from Summit and Discount when I've ordered other parts from them.
The cap/plug itself is now so buggered up I don't want to use it.
The hex (for an allan wrench) was rounded out by someone before me and is now filled with the remains of a torx I tried. The vise grip used to get it out pretty much uglified the circumference of the plug.
Given that, I would not feel confident of getting it ever on securely let alone every getting it off again. Also, there's gotta a be a reason it apparently blew out once before. I'm just hoping it is the plug itself and not the cylinder. I guess the factory oring could have failed initially and the "other guy" used one not rated for hydraulics.
I got the order in too late to ship yesterday, so ships today, maybe get it Friday or Saturday.
   / Kubota, Leaky fitting, anyone familiar with this one? #15
Managed to get a torx in there after moving the cross over hoses away, but it broke immediately. Chinesium bit, hollow apparently. Odd.
Finally got it out with a long nose vise grip after much coaxing. The seal is definitely blown out and is not a black oring but kind of yellow green, almost like ac (freon) oring. Certainly not going to use that plug again, so, I'll just order up a couple plugs with seals. I hope. It's only money.
Sounds like you used a tamper proof torx bit.
Yep. Only one I had that could fit in the hole. Still, not much force was applied.
2022 ELITE 102" X 40' GOOSENECK TRAILER (A50459)
2022 ELITE 102" X...
2025 K1220 UNUSED Single Garage Metal Shed (A50860)
2025 K1220 UNUSED...
2015 F-550 Bucket Truck. (A51039)
2015 F-550 Bucket...
2021 Case IH Magnum 240AFS CVX Connect MFWD Tractor (A50657)
2021 Case IH...
2015 Top Hat T/A 20 ft. Gooseneck Trailer (A50860)
2015 Top Hat T/A...
CATALOG IS A GUIDE ONLY!! (A50775)
CATALOG IS A GUIDE...
