kubota LA352 loader stuck in float position
   / kubota LA352 loader stuck in float position #1
mya
b2410 kubota
kubota la352 loader stuck in float position still after having detent replaced with new , any thoughts or help appreciated
   / kubota LA352 loader stuck in float position #2
Did you replace the parts or the dealer maybe its not back together correct.
A very reputable hydraulic repair shop rebuilt detent
i have seen posts with this same problem but no solutions
   / kubota LA352 loader stuck in float position #5
It might just be hard to pull it out of detent.
its normally harder to pull out but now it will only come out if i hit the bottom of the control lever with a hammer, and dont want to make worse
   / kubota LA352 loader stuck in float position #7
Id try a light spray oil to the parts. I see that its a common problem with that loader valve.
where would you spray oil specifically? everything is well lubricated externally, are you thinking inside the valve ? thanx
   / kubota LA352 loader stuck in float position #9
The cup on the bottom some people drill a little hole to let the water out I'd take that off and spray up in inside that the balls and spring.
   / kubota LA352 loader stuck in float position #10
messicks shows a break down of that valve.
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A52377)
2021 Allmand Bros...
John Deere Gator Utility Cart (A50324)
John Deere Gator...
2019 Chevrolet Cruze Sedan (A53424)
2019 Chevrolet...
Plasmarc PM150 Plasma Cutter (A51691)
Plasmarc PM150...
Utility Trailer (A52377)
Utility Trailer...
2012 Chevrolet Traverse LTZ SUV (A53424)
2012 Chevrolet...
