Kubota l5740 third function hydraulics
/ Kubota l5740 third function hydraulics #1
Jrbecker32
I would like to add third function hydraulics on my l5740 dealer wants almost 1000 dollars just for parts seems high to me. Where is the best place to purchase a kit ? Thanks
/ Kubota l5740 third function hydraulics #2
I got mine from the dealer as a package and paid less, but still not cheap. I'd check with Fit Rite and Kens Bolt On Hooks. You can go for the whole setup or diverter setup.
/ Kubota l5740 third function hydraulics #3
W.R.Long makes a kit but it's not going to be a lot cheaper.Paid about $900(factory) for mine installed.
/ Kubota l5740 third function hydraulics #4
If you want your control levers in the factory slots, I know of no other option than the factory kit for the valves. You can buy the cylinders elsewhere.
/ Kubota l5740 third function hydraulics #5
3rd function on the loader? Going rate is generally $1000-1500 installed. A diverter will be a bit cheaper & work nearly as well.
/ Kubota l5740 third function hydraulics #6
The OEM Kubota solution for a 3rd function on the loader has one of the on/off button held onto the joystick with a hose clamp. The open/close buttons are nicely integrated into the handle & the rest of the install looks OEM. Just not that 1 button. And I've seen that on enough other Kubotas to know it wasn't just my dealer half-assing it.
/ Kubota l5740 third function hydraulics #7
Ayyuuupp! I'm bad for confusing "3rd function" with "3 rear remotes".
New/Unused Landhonor Quick Attach 3 Point Hitch Adapter (A65583)
New/Unused...
211453 (A62131)
211453 (A62131)
New/Unused ATS Grass Proof Cloth (A65583)
New/Unused ATS...
Well Tank (A64127)
Well Tank (A64127)
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
6' STACKING RAKE (A64276)
6' STACKING RAKE...
