Kubota l5740 third function hydraulics
/ Kubota l5740 third function hydraulics #1
Jrbecker32
I would like to add third function hydraulics on my l5740 dealer wants almost 1000 dollars just for parts seems high to me. Where is the best place to purchase a kit ? Thanks
/ Kubota l5740 third function hydraulics #2
I got mine from the dealer as a package and paid less, but still not cheap. I'd check with Fit Rite and Kens Bolt On Hooks. You can go for the whole setup or diverter setup.
/ Kubota l5740 third function hydraulics #3
W.R.Long makes a kit but it's not going to be a lot cheaper.Paid about $900(factory) for mine installed.
/ Kubota l5740 third function hydraulics #4
If you want your control levers in the factory slots, I know of no other option than the factory kit for the valves. You can buy the cylinders elsewhere.
/ Kubota l5740 third function hydraulics #5
3rd function on the loader? Going rate is generally $1000-1500 installed. A diverter will be a bit cheaper & work nearly as well.
/ Kubota l5740 third function hydraulics #6
The OEM Kubota solution for a 3rd function on the loader has one of the on/off button held onto the joystick with a hose clamp. The open/close buttons are nicely integrated into the handle & the rest of the install looks OEM. Just not that 1 button. And I've seen that on enough other Kubotas to know it wasn't just my dealer half-assing it.
/ Kubota l5740 third function hydraulics #7
Ayyuuupp! I'm bad for confusing "3rd function" with "3 rear remotes".
20x20 Car Port (A65640)
20x20 Car Port...
2025 TEXAS PRIDE 14FT T/A DUMP TRAILER (A59914)
2025 TEXAS PRIDE...
2000 Artic Cat ZR600 Limited Edition Snow Mobile (A62613)
2000 Artic Cat...
1996 International 4700 (A64127)
1996 International...
New/Unused Landhonor 60 Gallon Sand Blasting Cabinet (A65583)
New/Unused...
60in. Work Bench (A65640)
60in. Work Bench...
