Kubota l5740 third function hydraulics
   / Kubota l5740 third function hydraulics #1
Jrbecker32
I would like to add third function hydraulics on my l5740 dealer wants almost 1000 dollars just for parts seems high to me. Where is the best place to purchase a kit ? Thanks
   / Kubota l5740 third function hydraulics #2
I got mine from the dealer as a package and paid less, but still not cheap. I'd check with Fit Rite and Kens Bolt On Hooks. You can go for the whole setup or diverter setup.
   / Kubota l5740 third function hydraulics #3
W.R.Long makes a kit but it's not going to be a lot cheaper.Paid about $900(factory) for mine installed.
   / Kubota l5740 third function hydraulics #4
If you want your control levers in the factory slots, I know of no other option than the factory kit for the valves. You can buy the cylinders elsewhere.
   / Kubota l5740 third function hydraulics #5
3rd function on the loader? Going rate is generally $1000-1500 installed. A diverter will be a bit cheaper & work nearly as well.
   / Kubota l5740 third function hydraulics #6
The OEM Kubota solution for a 3rd function on the loader has one of the on/off button held onto the joystick with a hose clamp. The open/close buttons are nicely integrated into the handle & the rest of the install looks OEM. Just not that 1 button. And I've seen that on enough other Kubotas to know it wasn't just my dealer half-assing it.
   / Kubota l5740 third function hydraulics #7
Ayyuuupp! I'm bad for confusing "3rd function" with "3 rear remotes".
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A56436)
2023 New Holland...
New Holland 650 Hay Baler (A53317)
New Holland 650...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A59230)
2004 Pierce Tilt...
2014 Ford Fusion SE Sedan (A59231)
2014 Ford Fusion...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
2020 HINO 268 26FT NON CDL BOX TRUCK (A59575)
2020 HINO 268 26FT...
