Kubota L4740 return to sump
   / Kubota L4740 return to sump #21
   / Kubota L4740 return to sump #22
Went out and took a pic of the fitting I plan to install to bypass the quick coupling. The arrows point to where the fitting will be attached. I'm still not sure this will work, but if it does, it will be a cheap modification. Although, it will be a little more difficult to connect than my current set up.
   / Kubota L4740 return to sump #23
I see you are a commercial applicator. So am I but a different venue. Mine is farming so I hold a State Pesticide / Herbicide application license.
I don't quite understand all the plumbing hoopla here. On my M's (which I believe are open center), I dump the fluid back into the transmission case via a threaded port (factory) on the rear cover. My loader dumps there and so does my hydraulically powered ditch mower.
   / Kubota L4740 return to sump #24
I don't think such a port exists on my Grand L's. A picture of yours would be helpful.
   / Kubota L4740 return to sump #25
I'm really not photogenic. Suffice to say the PTO back cover on both mine has a drilled and tapped port where you can attach a return hose. In fact, on my 540/1000 pto M9, there are two ports, one tapped and plugged, the other tapped and an elbow fitting installed. That is where the return from the loader goes back into the gearcase. The drilled and tapped port is on a centerline midway between the bottom of the PTO shaft and the top which dumps the return fluid back into the case at the correct level. My open station has just one. I added a Tee in both return lines to run a hydraulic motor on one of my implements. Was painless.
if you don't have a port in the PTO cover, Sure is easy to pull the cover and add a port, lots easier than what I see you folks doing. The back cover removes in maybe 30 minutes. Only thing you have to be aware of is the transfer shaft from the wet PTO clutch needs to stay in the clutch basket. Do not remove it. it has a loose coupler and if you remove the shaft when you pull the rear cover, the coupler will fall down into the gearcase, bad deal. It is 'fishable' from the fluid but getting the shaft back in the basket is a nightmare because the pto wet clutch is on the other side of the final drives and not very accessible. When you pull the back cover, the shaft won't come with the cover so don't pull it out. The PTO gearset and support castings are all part of the rear cover, so it is heavy and you'll need Kubota 3 Bond for reassembly. I've had both of mine apart in the past.
Easiest way to pull the rear cover without making a fluid mess is back the tractor up on ramps to tilt it forward after draining a couple gallons of fluid. No need to completely drain it.
I don't get all the complex plumbing, no need to in my view. Whatever blow your skirt up I guess. I like things simple.
Finally, you really need to give it a bath. Tractor is filthy. Better to see leaks when things are at least somewhat clean.
   / Kubota L4740 return to sump #26
I don't understand how that fitting is going to work for you. Show a picture when you get it in. I jumped the gun a little I do understand now. Why not just put a tee there if you are just using one or the other?
   / Kubota L4740 return to sump #27
A 'tee' might work too. I had not thought of that. I'll look into it. It may be a while before I try this, because I can still use my other tractor, and just wanted to have this tractor as a backup option if needed.
   / Kubota L4740 return to sump #28
You do know that is not a direct return to tank. To make return to tank you would have to move lever one way or the other and that would put pressure on the other.
   / Kubota L4740 return to sump #29
I don't understand what you are trying to tell me. I do move the lever to one side and lock it in place with a rubber strap. This provides constant pressure to my blade.
Is the 'tee' not a direct return? Or is the fitting I showed not a direct return to the tank?
   / Kubota L4740 return to sump #30
Yes it would be then as you are tie off your lever.
2012 LEEBOY 8515B APHALT PAVER (A51406)
2012 LEEBOY 8515B...
UNUSED CFG Industrial H15R Mini Excavator (A47384)
UNUSED CFG...
2016 CATERPILLAR D5K2 LGP CRAWLER DOZER (A51242)
2016 CATERPILLAR...
New 4x6 Chicken Coop (A50774)
New 4x6 Chicken...
Case 721B (A47384)
Case 721B (A47384)
2014 CATERPILLAR 259D SKID STEER (A51242)
2014 CATERPILLAR...
