Rear Blade Kubota L4740 rear blade selection question
   / Kubota L4740 rear blade selection question #1
Danc
Quebec, Canada
L4740
Hi,
I have a Kubota L4740 and am looking to buy a rear blade for it. My dealer offered me a 7 feet Buhler series 60 at 405 lbs. I was looking at the 80s series at 939 lbs.
Anyone can give me advice out there with this? I am afraid that the series 60 blade would be too light for my tractor.
Thank you in advance
Dan
   / Kubota L4740 rear blade selection question #2
What will you be using it for?
   / Kubota L4740 rear blade selection question #3
Hi,
Dan
I would be looking at the 80 series with a 96" blade. You will be a lot happier with a better, heavier blade. Does your tractor have a cat 1 or 2 hitch? The 80 series is cat 2 only, so that might be a problem. You may need to look at other manufacturers to be able to get that quality of blade with a cat 1-2 hitch.
I will be using it to level/grade trails and a private road on my property.
Also want to use it for snow removal.
I am also concerned about the blade being too light.
My tractor has a cat 1 3 point hitch.
Thanks for the insight.
   / Kubota L4740 rear blade selection question #5
Take a look at a Land Pride RBT35 series blade. They are cat 1&2, heavier and have hydraulic options. :thumbsup: This is the blade that I hope to get for my 3215 someday, very nice piece of equipment. ;) I don't think that any other manufacturer has an equivalent of this blade at this time. All the others that I have looked at are all cat 2 only.
Sweet thanks I ll look into it, the landpride seems about 100 lbs heavier and I want it with the hydraulic option for sure.
Thanks again.
2025 GIYI GY-SZYMJ Hydraulic Stump Grinder Mini Skid Steer Attachment (A56857)
2025 GIYI GY-SZYMJ...
2025 AGT H15R Mini-Excavator with Dozer Blade & Pilot Controls  (New/Unused) (A59225)
2025 AGT H15R...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52709)
2007 CATERPILLAR...
2013 Ford F-250 Super Duty Service Truck, VIN: 1FT7X2BT7DEB91437, Extended Cab, 4x4, 6.7 L Power (A59076)
2013 Ford F-250...
2010 INTERNATIONAL DURASTAR 4300 SWEEPER TRUCK (A51406)
2010 INTERNATIONAL...
Hypertherm Powermax65 Plasma Cutter w/Cart, PIN 083266, S/N 65-067003 (A59076)
Hypertherm...
