Rear Blade Kubota L4740 rear blade selection question
   / Kubota L4740 rear blade selection question #1
Danc
Member
Quebec, Canada
L4740
Hi,
I have a Kubota L4740 and am looking to buy a rear blade for it. My dealer offered me a 7 feet Buhler series 60 at 405 lbs. I was looking at the 80s series at 939 lbs.
Anyone can give me advice out there with this? I am afraid that the series 60 blade would be too light for my tractor.
Thank you in advance
Dan
   / Kubota L4740 rear blade selection question #2
What will you be using it for?
   / Kubota L4740 rear blade selection question #3
Hi,
Dan
I would be looking at the 80 series with a 96" blade. You will be a lot happier with a better, heavier blade. Does your tractor have a cat 1 or 2 hitch? The 80 series is cat 2 only, so that might be a problem. You may need to look at other manufacturers to be able to get that quality of blade with a cat 1-2 hitch.
I will be using it to level/grade trails and a private road on my property.
Also want to use it for snow removal.
I am also concerned about the blade being too light.
My tractor has a cat 1 3 point hitch.
Thanks for the insight.
   / Kubota L4740 rear blade selection question #5
Take a look at a Land Pride RBT35 series blade. They are cat 1&2, heavier and have hydraulic options. :thumbsup: This is the blade that I hope to get for my 3215 someday, very nice piece of equipment. ;) I don't think that any other manufacturer has an equivalent of this blade at this time. All the others that I have looked at are all cat 2 only.
Sweet thanks I ll look into it, the landpride seems about 100 lbs heavier and I want it with the hydraulic option for sure.
Thanks again.
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A55852)
2014 Peterbilt 384...
2019 Doosan LCV6W Towable LED Light Tower (A51691)
2019 Doosan LCV6W...
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A55315)
UNVERFERTH 330 -...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A57024)
LIKE NEW 2023...
Generac 11kW Natural Gas Generator (A55851)
Generac 11kW...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
