Rear Blade Kubota L4740 rear blade selection question
   / Kubota L4740 rear blade selection question #1
Danc
Quebec, Canada
L4740
Hi,
I have a Kubota L4740 and am looking to buy a rear blade for it. My dealer offered me a 7 feet Buhler series 60 at 405 lbs. I was looking at the 80s series at 939 lbs.
Anyone can give me advice out there with this? I am afraid that the series 60 blade would be too light for my tractor.
Thank you in advance
Dan
   / Kubota L4740 rear blade selection question #2
What will you be using it for?
   / Kubota L4740 rear blade selection question #3
Hi,
Dan
I would be looking at the 80 series with a 96" blade. You will be a lot happier with a better, heavier blade. Does your tractor have a cat 1 or 2 hitch? The 80 series is cat 2 only, so that might be a problem. You may need to look at other manufacturers to be able to get that quality of blade with a cat 1-2 hitch.
I will be using it to level/grade trails and a private road on my property.
Also want to use it for snow removal.
I am also concerned about the blade being too light.
My tractor has a cat 1 3 point hitch.
Thanks for the insight.
   / Kubota L4740 rear blade selection question #5
Take a look at a Land Pride RBT35 series blade. They are cat 1&2, heavier and have hydraulic options. :thumbsup: This is the blade that I hope to get for my 3215 someday, very nice piece of equipment. ;) I don't think that any other manufacturer has an equivalent of this blade at this time. All the others that I have looked at are all cat 2 only.
Sweet thanks I ll look into it, the landpride seems about 100 lbs heavier and I want it with the hydraulic option for sure.
Thanks again.
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A56435)
Ditch Witch 6510A...
2025 Wolverine MAD-12-12D Auger Mini Skid Steer Attachment (A56857)
2025 Wolverine...
2011 International DuraStar 4300 12ft Flatbed Truck (A55973)
2011 International...
2000 INTERNATIONAL 4700 (A58214)
2000 INTERNATIONAL...
(APPROX. 640BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 640BF)...
2017 Ram 1500 SLT Crew Cab Pickup Truck (A56858)
2017 Ram 1500 SLT...
