Rear Blade Kubota L4740 rear blade selection question
   / Kubota L4740 rear blade selection question #1
Danc
Quebec, Canada
L4740
Hi,
I have a Kubota L4740 and am looking to buy a rear blade for it. My dealer offered me a 7 feet Buhler series 60 at 405 lbs. I was looking at the 80s series at 939 lbs.
Anyone can give me advice out there with this? I am afraid that the series 60 blade would be too light for my tractor.
Thank you in advance
Dan
   / Kubota L4740 rear blade selection question #2
What will you be using it for?
   / Kubota L4740 rear blade selection question #3
Hi,
Dan
I would be looking at the 80 series with a 96" blade. You will be a lot happier with a better, heavier blade. Does your tractor have a cat 1 or 2 hitch? The 80 series is cat 2 only, so that might be a problem. You may need to look at other manufacturers to be able to get that quality of blade with a cat 1-2 hitch.
I will be using it to level/grade trails and a private road on my property.
Also want to use it for snow removal.
I am also concerned about the blade being too light.
My tractor has a cat 1 3 point hitch.
Thanks for the insight.
   / Kubota L4740 rear blade selection question #5
Take a look at a Land Pride RBT35 series blade. They are cat 1&2, heavier and have hydraulic options. :thumbsup: This is the blade that I hope to get for my 3215 someday, very nice piece of equipment. ;) I don't think that any other manufacturer has an equivalent of this blade at this time. All the others that I have looked at are all cat 2 only.
Sweet thanks I ll look into it, the landpride seems about 100 lbs heavier and I want it with the hydraulic option for sure.
Thanks again.
2018 John Deere 35G Mini Excavator (A49461)
2018 John Deere...
New/Unused 20ft Farm Metal Driveway Gate (A48837)
New/Unused 20ft...
2011 FREIGHTLINER M2 26FT BOX TRUCK (A50505)
2011 FREIGHTLINER...
2009 L3 GENERATOR SET (A51222)
2009 L3 GENERATOR...
RIDE AND DRIVE INFO (A50774)
RIDE AND DRIVE...
2015 FORD F-250XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-250XL...
