kubota l4310 adding remotes
/ kubota l4310 adding remotes #1
rymo
kubota l4310
I have a kubota l 4310. I have a hydraulic thing with three plugs and three nuts nearthe brake pedals can I tap into that or do I have to buy the block from kubota?
/ kubota l4310 adding remotes #2
Can you post a picture?
We can help more easily then.
/ kubota l4310 adding remotes #3
I assume you are referring to the mount under the floorboards where the filter is located?
Do you have any other hydraulics on the tractor other than the three point? If not the answer is yes you can hook into that for rear remotes. You will need a control Valve with power beyond capability. Other than that the hookup is pretty straightforward.
/ kubota l4310 adding remotes #4
If he did have a loader on the tractor, does that change the answer? I'm only asking for the OP's benefit......not because I just happen to be doing the same thing on my L4610 :D
/ kubota l4310 adding remotes #5
If there's a loader, the easiest place to tap into is between the loader and the 3ph. If not, you need to go into the hydraulic distribution block before the 3ph. It has to be a series circuit in any case.
Sean
2006 Ford F-350 12ft. Flatbed Truck (A61573)
2006 Ford F-350...
2007 Freightliner FLD120 (A62679)
2007 Freightliner...
Ford TW20 (A64119)
Ford TW20 (A64119)
2016 FREIGHTLINER CASCADIA 125 T/A DAYCAB TRACTOR TRUCK (A59912)
2016 FREIGHTLINER...
2013 Honda Pilot AWD SUV (A61574)
2013 Honda Pilot...
2017 Forest River Rockwood HW275 S/A Pop Up Camper Trailer (A61574)
2017 Forest River...
