Kubota L3901
/ Kubota L3901 #21
My dealer said the new Tier 4 tractors would be about $4k more expensive than their Interim counterparts.
As for having a cab, I haven't even taken delivery of my new tractor yet and I'm wanting a cabbed tractor :) I told the wife the next one will have a cab for sure. I can get by in the winter by plugging in my electric heated gear on the tractor, but it's still not as comfortable as a cab would be.
/ Kubota L3901 #22
I've told the story before, but my wife actually to buy a cabbed tractor instead of open station. LONG story, but I picked out a GL39/4240 open station when she told me to get a cab; man was she right on that one.
/ Kubota L3901 #23
It was hard enough to convince her that I needed to go from the $22k L series I was originally looking at up to the nearly $30k MX5100 so I didn't buy something too small the first time around. Spending an extra $15k on a cabbed Grand L with the same HP this time around would have been a tough sell.
/ Kubota L3901
I was guided from the **00 series to the grand L due to the differences in hydraulic capabilities, and therefor on loader and backhoe capabilities.
My personal observations were that the **00 series seemed to have more exposed breakables down low, where the grand L had the same pieces either better tucked away, or simply higher.
And (at least going by their brochures) the grand L keeps all of the nifty power and computer controlled HST functionality.
The grand L series is definitely a step up, both in features and unfortunately in price too. The problem I see is that with an added $4k in price, you don't get much more except hopefully a smooth 3 point hitch. The 3901 is still an economy series machine, now with a considerably higher price, thanks to a DPF filter system and common rail injection. I really haven't looked at prices across the market since I'm not looking to buy, but I'd suspect the big players are all pretty much the same. That means fewer buyers or more debt load for those that do take the plunge.
Sean
/ Kubota L3901 #25
I know what you mean, I just happened to get lucky and there was a used L5030HSTC at the dealer, so the cost was less than a new 4240 open station. Then when the L60's came out, I traded the L5030 in on an L5740 and got almost what I paid for it and put close to 800 hours on it; incrementalism can be your friend. If we had priced a new cab unit right off the bat, we both probably would have stroked out; worth it in the end though.:laughing:
/ Kubota L3901 #27
So what's the price? You know you should have included this with your post now don't you???
I'm looking for my first tractor right now and got quotes from the local Kubota dealers for both the L3301 and L3901. $21,200 for the 3301 and $23,600 for the L3901. I'm trying to justify the extra $2400 for 6 more HP.
/ Kubota L3901 #28
It really depends on exactly what you will be using the tractor for. PTO implements, nice to have the additional power. Ground work, nice to have the extra power. People have stated that unballasted, the lower HP models are fine. Fill the tires and you need the additional HP to make full use of the machines capabilities. ;)
/ Kubota L3901 #29
I have a L3200 (pre emissions L3301) with R4s. Unloaded tires left me with traction limits. Now that they are loaded I hit HP limits most of the time. I'm running a HST which is a little less efficient than a geared tranny, so loose an extra HP or 2 there.
I regret not getting a L3800, but I'm not sure its over $2k of regret, maybe $1k. I just have to go slower when running the tiller & be more carefully pushing & scooping at the pile. I haven't had to slow much mowing my field, usually a rough ride is the limiting factor. The extra HP will be nice if you are in a hurry, but not much if you putter at a slower pace. The HP has no impact on what the tractor will do, just how fast it will do it, at least with a HST.
I will be replacing my tractor eventually with a higher HP one, but it will be a cabbed grand or other premium model. The cab & other features are the driver not the HP though, I wouldn't bother trying to upgrade to a L3800.
/ Kubota L3901
Pretty much what everybody else is saying.. You need as much hp as you need to get the job done. Why pay for more if you don't need to?
I've never regretted buying the L3400 (other than a jerky 3-point), for power reasons. It runs a 5-foot cutter just fine, will move small round bales, etc. It does what I need done as fast as I want it done. More power = less time, sure. It also means more fuel, more weight, wider roads, more money up front. Buy what you need..
/ Kubota L3901 #31
Actually the L3200 vs L3800 or the new 01 equivalents are the same tractor, possibly even the same engine, only tuned for the extra 6hp (haven't ever bothered to confirm that for sure). So no extra weight or width. There might be a hair different gear ratios involved, but that's it. I'm sure it burns 6hp more fuel though.
As the R4's have less traction than R1's I expect the R1's run into power limits as opposed to traction limits faster. I'd say 60-70% of the time I'm speed limited by rough terrain (which is actually a reasonably flat & smooth). 10-15% of the time I wish I had more HP, because I'm impatient.
Also, get the rear tires loaded no matter what. Lifting something heavy & turning the wheel to have the back slide sideways rather than the front turn, even with an implement on the back isn't a good for your or your tractor's health. I'm glad I didn't have the tires loaded from the get go (dealer didn't have the equipment at the time) so I could learn the value of loading the rears for ballast & traction, but I'll never get another one without loaded tires again.
/ Kubota L3901
Agreed, looking for more power often leads into a bigger machine however. Or, in some cases it's cheaper or easier to buy a bigger used tractor whether you need one or not.
/ Kubota L3901 #33
So I'm meeting the dealer this Friday to get my first tractor for my 13 acre property. Probably 2/3 of it is woods, but we're planning on clearing some of it out for a barn, paddock area for 2 horses, maybe an out building or two. The trees are pretty crowded, so except for the perimeter, a lot of the trees are about 3o feet tall and 2 inches in diameter! Any major excavation for foundations, etc. will have to be contracted out, so I'm just looking for a tractor to do the pasture cutting (two ~2 acre areas) and minor landscaping (moving piles of dirt around), hauling firewood and horse hay (bales, probably not rounds). My question for all of you since I've only been on a tractor long enough to drive from one end of the parking lot to another is, would the extra 6 hp in the L3901 be worth the extra $2500? Or, in other words, would it I even notice a difference? There is really no other difference between the two models (L3901 and L3301). I'm thinking it really comes down to the PTO hp since it sounds like the push/pull hp of a tractor really relates to how fast you can get the job done. I have no problem slowing things down; I'm not on the clock! My biggest concern would be that 25 PTO hp sounds like about the minimum requirement formost rotary cutters (the L3301 is about 26 hp according to Kubota), but I wouldn't want to be pushing the tractor to the max. Would the extra 4 PTO hp (L3901 is rated at 30.6 hp) be "easier" on the engine if the same cutter was being used? I guess I'd be in the same boat if I was looking at a 30hp minimum cutter with the 3901, but I just don't want to be putting undue stress on the tractor. What are your suggestions? Other than the rotary cutter, about the only thing I can think of needing would be a post hole digger for putting up the fence and maybe a rented tiller if I can't get the pasture smoothed out well enough with a box blade and drag harrow. Most of the work will be clearing paths through brush and small trees and hauling hay and feed and manure around.
/ Kubota L3901 #34
If you get the hydro transmission you probably won't notice it.. Sure the extra horsepower may allow you to go thru thick stuff faster. But as you said, you can slow down. With the hydro, just back off of the hydro pedal and go as slow as you need to go to keep the engine RPM up. If you have a gear drive the difference MIGHT or might not require you to drop down one gear to keep your RPM's up. It is hard to say for sure..
It just depends on what you are cutting and how fast you are pushing it. The tractor costs more, but if you trade it in, it will appeal to a larger group of buyers, and you are likely to get more for it on a trade or outright sale.
It is like anything else, when you increase things in small increments, you will likely notice it, but it is not a night and day noticeable.
If you compared a 30 horse tractor to a 50 horse tractor, you are going to notice a pretty large difference, plus the 50 horse machine is likely to have a much larger frame and take larger implements. In my opinion, for the majority of your work, you are not going to notice much of a difference, especially if you are not trying to make a living with the machine.
/ Kubota L3901 #35
Weight defines what a tractor will do. HP just defines how fast it will do it. If your fine slowing it down & taking it easy, there is no reason for the extra HP.
/ Kubota L3901 #36
Will you be snowblowing deep snow? That job seems to eat up HP.
The 3301 should be fine running a 5 foot cutter.
If you want to run a 6', then I'd look to the 3901.
/ Kubota L3901 #37
so I just purchased a new L3901 HST. the HST seems to be very loud. everything works fine and the fluid level is correct, just seems really loud. any thoughts from the experts? Also, it seems the loader is not as strong as I would have thought. the other Kubota's I have had would pick up the rear of the tractor and basically had more loader power than tractor weight. This one seems to be very low on weight capability.
/ Kubota L3901 #38
I bought the L3901 HST over 2 years ago. I have R1 tires filled with best juice for added weight. I have 75+hours on it and have had about 4 regens on it. It has done everything I have asked it to including moving some pretty heavy boulders and smaller round bales. I have no comparison for older Kubota tractors since my first was a 1960 Ford 641.
/ Kubota L3901 #39
HSTs are generally a fair bit louder than a gear machine. Noise is a bit higher in pitch too across most all the brands I've heard. Hard to say without hearing it, I'd ask your dealer. Using Super UDT or SUDT2 hydraulic fluid really makes a difference on noise for HST machines. It should be the OEM fluid though, unless the dealer did something kind of messed up.
The L3901 should be the same frame & loader as my old L3200... With loaded R4s a 5' rotary cutter with 200lbs of crap on the back of the cutter for extra ballast I could barely keep the back end on the ground if I pushed it. I was lifting "1,200 lbs" big square hay bales for a friend. Add in 200lbs for the forks & more for the 2' or the center of gravity on the hay bales being out there a bit & it was well over the 1,200lbs rating on the loader. I could only lift them 4' high or so, depending on the bale. Back end was really close to coming off the ground in many instances. So the tractor & ballast was the weak point, not the loader. Might want to check the pressure on your relief valve to see if that is under spec causing your weakness.
/ Kubota L3901 #40
My 2501 will lift a half a pallet of pellets and forks, but the back end gets really light even with a blade, weights and loaded tires. Sounds like your relief pressure might be low.
HST whine is a little concerning at first, but you get used to it to the point that you forget after a while. Some nice Worktunes helps a lot with the noise.
