Kubota L3901 check engine light
   / Kubota L3901 check engine light #1
Nickelpickel
Kubota L3901
my 2020 K L3901 after plowing snow in normal fashion on way into garage mufflers begins a low hot rod sound, rt side single red check engine light comes on and produces very little power as limped it 10’ into garage. 300 hrs all fluids checked , oil looked really blk Will be contacting my dealer, but i would like thoughts of those in the know, thanks
   / Kubota L3901 check engine light #2
Does that have dash codes? if yes, what are they? If no, do you have a code reader/adapter cable etc.? Common errors on those seem to be P0087 (low fuel rail pressure) P3008(cam position sensor) P3001 (emissions deterioration). Any lights indicating it's in regen?
no regen lights no codes
no regen no codes
   / Kubota L3901 check engine light #5
Any updates?
2018 Ford F-350 4x4 Ext. Cab Stellar FC3200 3,200lb 1.5 Ton Service Crane Truck (A55973)
2018 Ford F-350...
1269 (A58374)
1269 (A58374)
TANK MANIFOLD (A55745)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
1287 (A58374)
1287 (A58374)
