Kubota L3800 trailer
   / Kubota L3800 trailer #11
18 feet. I'm never going back to non tilting trailer, or wooden deck.
Looks like a nice trailer & $4k for a nearly new tilting deck is great. How long is the deck?
   / Kubota L3800 trailer #12
I've got a 81" X 20' on order. Went ahead and spent an extra $800 to upgrade to a 10k trailer. I figured a 7k would be pretty close to max plus just seeing the size of the brakes on the 5,200lb vs 3,500lb axles was worth it to me.
   / Kubota L3800 trailer #13
Good call. Heavier axles ride a bit harsher, but are safer & more flexible in what you can haul.
   / Kubota L3800 trailer #14
I have 18' (16' + 2' dovetail) 7k trailer brakes on both axles. It functions ok, but if I were to do it over it would be 20' (18' + 2' dovetail) 10k trailer. Since op asked 16' or 18' as choice....18' with 10k axles would be minimum with 20' length better.
The weight of trailer between the sizes is minimal. At times a good trailer has features that can make use a better experience rather than a pain in the rear. I have three different types of trailers: hauler, dump and small aluminum utility....they all work well, but with experience would alter each one if buying again...experience as teacher.
A couple things I did learn from first cheap landscape trailer I had to current hauler was: slide in rear ramps with the ramps being reinforced smooth plate on top and not ladder style (allows loading small tire items) 16" wide vs 12" , and tapered bed on front along with tapered tongue tool box.
   / Kubota L3800 trailer #15
I have an L3200HST with a backhoe. I haul mine on a 16' 7K trailer. If I had it all to do over again, I wouldn't hesitate to get an 18' 10K trailer. You'll never regret it.
   / Kubota L3800 trailer #16
I don't think a 10K trailer is needed for his setup. It will only overwork the F150. My vote is 18' 7k trailer. Fine for what you are doing.
   / Kubota L3800 trailer #17
What's the weight difference?
   / Kubota L3800 trailer #18
I was told on a 20' the difference between 7k & 10k is maybe 500lbs which makes sense. My F150 won't notice it as far as pulling power goes and it will appreciate having an extra 2' to tweak tongue weight or throw more crap on the trailer. Just seeing the size difference in the brake drums was enough for me...
   / Kubota L3800 trailer #19
Check your local DMV laws, you might want to have that as a 9,950 trailer. And what's a "10K trailer"? My Hudson is 12,000 lbs GVW but labelled (by Hudson) as a 5 ton.
The slight extra weight will be quickly forgotten if he has to haul an extra couple of thousand pounds.
My trailer/tractor combo was ridiculous when I bought it in 2009.
A 12k GVW trailer for a 2k tractor.
467336d1462331786-kubota-l3800-trailer-tractor-015small-jpg
But when I need to haul my M4700 (bought 4 years later in 2013) from DC to Mississippi it came in right handy, just a little narrow.
467337d1462331827-kubota-l3800-trailer-20140427_103025-jpg
The tires barely fit in the 78" between the wheel wells.
   / Kubota L3800 trailer #20
And you never know when you'll see something on the side of the road that you want to buy.
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A52748)
2018 John Deere...
2013 Audi Q7 AWD SUV (A51694)
2013 Audi Q7 AWD...
2008 Ford Escape Hybrid SUV (A51694)
2008 Ford Escape...
2019 FORD F-350 (A52472)
2019 FORD F-350...
NEW Wolverine Skid Steer Pallet Forks Hydro Adjustable (A53002)
NEW Wolverine Skid...
2002 INTERNATIONAL 4400 BEVERAGE TRUCK (A52576)
2002 INTERNATIONAL...
