Kubota L3400 keeps dying
   / Kubota L3400 keeps dying #11
I see this is an old post. So hoping it gets read. Did you ever figure out what the issue is. My l3400 is doing the exact same thing.
   / Kubota L3400 keeps dying #12
I have a kubota L3400 that is 2005 year model and it only runs about 30 seconds then dies. I have changed the fuel filter and had no luck, i have changed the engine fuel solenoid that turns the fuel off if a safety device trips. I can turn the key on and not start the tractor and in about 30 seconds the fuel solenoid clicks and will not allow me to start the tractor, if i turn the key and immediately starts the tractor it will start and run for about 30 seconds. Has anyone experienced this... Thanks
There is a timer relay (usually under the dash) that controls the fuel cutoff solenoid. It is probably failing and needs replaced.
   / Kubota L3400 keeps dying #13
Thank you I will explore that.
Carnival Ticket Booth (A51691)
Carnival Ticket...
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
STORAGE FEES (A54607)
JOHN DEERE 635F 35' HYDROFLEX PLATFORM HEADER (A51247)
JOHN DEERE 635F...
2018 GENIE GTH-844 TELESCOPIC FORKLIFT (A52706)
2018 GENIE GTH-844...
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
