Kubota L3400 keeps dying
   / Kubota L3400 keeps dying #11
I see this is an old post. So hoping it gets read. Did you ever figure out what the issue is. My l3400 is doing the exact same thing.
   / Kubota L3400 keeps dying #12
I have a kubota L3400 that is 2005 year model and it only runs about 30 seconds then dies. I have changed the fuel filter and had no luck, i have changed the engine fuel solenoid that turns the fuel off if a safety device trips. I can turn the key on and not start the tractor and in about 30 seconds the fuel solenoid clicks and will not allow me to start the tractor, if i turn the key and immediately starts the tractor it will start and run for about 30 seconds. Has anyone experienced this... Thanks
There is a timer relay (usually under the dash) that controls the fuel cutoff solenoid. It is probably failing and needs replaced.
   / Kubota L3400 keeps dying #13
Thank you I will explore that.
2016 CATERPILLAR 325FL EXCAVATOR (A52705)
2016 CATERPILLAR...
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
2012 VOLVO BL70B BACKHOE (A51246)
2012 VOLVO BL70B...
Mobile Transformer and Power Substation Portable Power Supply (A55218)
Mobile Transformer...
2014 BMW 328i Sedan (A53424)
2014 BMW 328i...
2004 Chevrolet Silverado 2500HD Service Truck (A53422)
2004 Chevrolet...
