newbury
Super Star Member
- Joined
- Jan 8, 2009
- Messages
- 14,885
- Location
- From Vt, in Va, retiring to MS
- Tractor
- Kubota's - B7610, M4700
Don't use tape.
Thanks.Brian thanks. 2 questions - are those metric threads on the Kubota block? And on the loader valve, how do I tell which hose is which?
Ed
BTW - your stuff looks very nice.
OK, This was interesting but I am a bit confused. I have a L3600 which has never had a FEL and I acquired an older Wood loader off another 3600 but not the fittings on the hydraulic block. The loader hoses (3) all have Safeway 20 series QD and I can get the missing parts to match. Are the threads on the Kubota hydraulic block metric or NPT?
And since I am going to be into it, I thought now is the time to add a pair of remotes off the back, for tilt and grader blade angle. I get that I will combine the returns so I need to tee before going into the block, correct? How do i know which hose goes to tank and which is PB? Does the PB line now go to the new remote valve? I am looking at the 2 SPOOL 8 GPM PRINCE MB21BB5C1 DA VALVE. Does the new valve need to set up as PB also or can it be an open center. This valve is rated 8 gpm max while the specifications list the 3600 at 7.8 gpm but on the hyd block detail page it is listed as 8.2 gpm. Sorry, i don't quite understand how PB works in this case.
Ed
