Kubota L245dt Question
   / Kubota L245dt Question #1
E119744
Caldwell, Ohio
Kubota L245DT
I am installing powersteering on my l245dt kubota , I mounted the steering valve under the dash . Im trying to figure the best way to supply the steering valve with hyd. fluid ...There is a block under my seat that has 4 bolts on the front and a hyd supply going through the middle of it . Can i get my power from there , If so how ? . Thanks
   / Kubota L245dt Question #2
Does your block look like this?
If so, I believe you could take power from the top left port (top left in the pic) or the bottom center. The top left feeds the power steering on this tractor, and the hose into the top of the crankcase (toward the right) is the return from the power steering.
   / Kubota L245dt Question #3
Is this a kit you ordered or did you do it all from scratch
2015 F-550 Bucket Truck Gas Engine (A51039)
2015 F-550 Bucket...
1989 Freightliner FLD120 (NEW CAT 3406A, NEW REAR ENDS, CLUTCH) (A51039)
1989 Freightliner...
2 ROLLS OF CORNING OPTICAL CABLE (A50854)
2 ROLLS OF CORNING...
2019 Ford Fusion Sedan (A50324)
2019 Ford Fusion...
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Lowboy Trailer (A49461)
2019 Fontaine...
2013 FREIGHTLINER CASCADIA (A50854)
2013 FREIGHTLINER...
