Kubota L245dt Question
   / Kubota L245dt Question #1
E119744
Caldwell, Ohio
Kubota L245DT
I am installing powersteering on my l245dt kubota , I mounted the steering valve under the dash . Im trying to figure the best way to supply the steering valve with hyd. fluid ...There is a block under my seat that has 4 bolts on the front and a hyd supply going through the middle of it . Can i get my power from there , If so how ? . Thanks
   / Kubota L245dt Question #2
Does your block look like this?
If so, I believe you could take power from the top left port (top left in the pic) or the bottom center. The top left feeds the power steering on this tractor, and the hose into the top of the crankcase (toward the right) is the return from the power steering.
   / Kubota L245dt Question #3
Is this a kit you ordered or did you do it all from scratch
CASE 850M WT CRAWLER DOZER (A51242)
CASE 850M WT...
19009 (A48082)
19009 (A48082)
2018 Toyota RAV4 SUV (A50324)
2018 Toyota RAV4...
2016 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A51242)
2016 CATERPILLAR...
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
2022 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
