Kubota L245dt Question
   / Kubota L245dt Question #1
E119744
Caldwell, Ohio
Kubota L245DT
I am installing powersteering on my l245dt kubota , I mounted the steering valve under the dash . Im trying to figure the best way to supply the steering valve with hyd. fluid ...There is a block under my seat that has 4 bolts on the front and a hyd supply going through the middle of it . Can i get my power from there , If so how ? . Thanks
   / Kubota L245dt Question #2
Does your block look like this?
If so, I believe you could take power from the top left port (top left in the pic) or the bottom center. The top left feeds the power steering on this tractor, and the hose into the top of the crankcase (toward the right) is the return from the power steering.
   / Kubota L245dt Question #3
Is this a kit you ordered or did you do it all from scratch
2016 VOLVO VNL300 TANDEM AXLE DAY CAB (A51222)
2016 VOLVO VNL300...
WEATHERFORD MP-10 TRIPLEX MUD PUMP POWERED BY A CATERPILLAR 3412 ENGINE (A50854)
WEATHERFORD MP-10...
2007 Volvo VNL Truck Tractor (A51039)
2007 Volvo VNL...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2019 Kubota F3990 72 in. Commercial Mower (A50324)
2019 Kubota F3990...
2006 STERLING LT9500 SERIES MIXER TRUCK (A50854)
2006 STERLING...
