kubota L2201 not starting
   / kubota L2201 not starting #1
dbharness
Memphis, TN
My Kubota L2201 is not starting. It isnt even turning over. Nothing. The charge light comes on. The battery is good. The alternator and starter are getting voltage. It was in neutral and i had the clutch engaged. The key was on.
Anyone have experience with this problem?
Any other way to chase this down. Do the neutral, clutch sensors or ignition switches go out on these?
Even though the battery has 12 volts, could a low amp battery cause this? I tried a battery jump off. No luck.
thanks
   / kubota L2201 not starting #2
If you have voltage at the small wire on the starter when turning the key, the solenoid is bad.
The wire you mentioned was loose. It was hard to notice. It looked fine. As i touched it with my meter i noticed it was very loose. Recrimped the terminal. Once tight, the tractor started right up.
thanks.
   / kubota L2201 not starting #4
Your welcome. Good to hear it was a simple fix.
WHITE PINE TONGUE & GROOVE (A60432)
WHITE PINE TONGUE...
2018 Chevrolet Impala Sedan (A59231)
2018 Chevrolet...
2020 Nissan Rogue SUV (A59231)
2020 Nissan Rogue...
2022 KOMATSU PC360LC-11 EXCAVATOR (A60429)
2022 KOMATSU...
KBH 25 TON TENDER (A61307)
KBH 25 TON TENDER...
2004 JOHN DEERE 160C LC EXCAVATOR (A59823)
2004 JOHN DEERE...
