kubota L2201 not starting
   / kubota L2201 not starting #1
dbharness
Memphis, TN
My Kubota L2201 is not starting. It isnt even turning over. Nothing. The charge light comes on. The battery is good. The alternator and starter are getting voltage. It was in neutral and i had the clutch engaged. The key was on.
Anyone have experience with this problem?
Any other way to chase this down. Do the neutral, clutch sensors or ignition switches go out on these?
Even though the battery has 12 volts, could a low amp battery cause this? I tried a battery jump off. No luck.
thanks
   / kubota L2201 not starting #2
If you have voltage at the small wire on the starter when turning the key, the solenoid is bad.
The wire you mentioned was loose. It was hard to notice. It looked fine. As i touched it with my meter i noticed it was very loose. Recrimped the terminal. Once tight, the tractor started right up.
thanks.
   / kubota L2201 not starting #4
Your welcome. Good to hear it was a simple fix.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2016 Ford Transit 350 Cargo Van (A59230)
2016 Ford Transit...
2016 UTILITY 53X102 REEFER TRAILER (A59905)
2016 UTILITY...
2019 CATERPILLAR 326FL EXCAVATOR (A60429)
2019 CATERPILLAR...
2021 Gehl RT215 Track Loader with 74in Smooth Bucket (A61306)
2021 Gehl RT215...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
