Kubota FL127
/ Kubota FL127 #1
Scrounger
Platinum Member
Bethlehem (Lower Nazareth) PA
Kubota BX2230
Anyone using a FL127 tiller on a BX2230. Its a 50" model and I'm trying to see how its going to work if you have to till a trail about two miles long. /forums/images/graemlins/smile.gif
/ Kubota FL127 #2
If you are looking at a Kubota FL1271 tiller then I think that is too large for the BX tractors. The B40C is a good tiller for the BX series tractors. Hope this helps.
Lewis
/ Kubota FL127 #3
Hi Matt,
My Muratori 37" on the BX2200 does very well on hard adobe clay in summer. This being the case, I'd think a bigger unit would do alright in a soil that is not as hard as mine. I remember older posts where folks talked about using tillers considerably bigger than mine on a BX with no problems. You might want to search the archives.
Most BXs (except 1500) are about 42" wide. For a lot of applications you might want something that's either wider than that, or if narrower than 42"-offset to one side. Otherwise, if 'tilling a field, it can be difficult or impossible to 'till the field without re-compacting portions with the tires.
Good luck with this.
BTW-I never heard back from you re. the exact measurement on your 3ph mid-height max. spread with the bh sub-frame in place. I'd appreaciate that measurement greatly.
PALLET FORK MOUNT SAFETY BASKET (A61572)
PALLET FORK MOUNT...
MINERAL FEEDER (A63291)
MINERAL FEEDER...
2001 Pierce Tilt Crew Cab Pumper Fire Truck (A61573)
2001 Pierce Tilt...
2021 Case 200 Magnum (A64119)
2021 Case 200...
(INOP) 2011 INTERNATIONAL PROSTAR PREMIUM ROAD TRA (A63291)
(INOP) 2011...
ROADTEC RX700 MILLING MACHINE (A64279)
ROADTEC RX700...
