Kubota FL127
/ Kubota FL127 #1
Scrounger
Platinum Member
Bethlehem (Lower Nazareth) PA
Kubota BX2230
Anyone using a FL127 tiller on a BX2230. Its a 50" model and I'm trying to see how its going to work if you have to till a trail about two miles long. /forums/images/graemlins/smile.gif
/ Kubota FL127 #2
If you are looking at a Kubota FL1271 tiller then I think that is too large for the BX tractors. The B40C is a good tiller for the BX series tractors. Hope this helps.
Lewis
/ Kubota FL127 #3
Hi Matt,
My Muratori 37" on the BX2200 does very well on hard adobe clay in summer. This being the case, I'd think a bigger unit would do alright in a soil that is not as hard as mine. I remember older posts where folks talked about using tillers considerably bigger than mine on a BX with no problems. You might want to search the archives.
Most BXs (except 1500) are about 42" wide. For a lot of applications you might want something that's either wider than that, or if narrower than 42"-offset to one side. Otherwise, if 'tilling a field, it can be difficult or impossible to 'till the field without re-compacting portions with the tires.
Good luck with this.
BTW-I never heard back from you re. the exact measurement on your 3ph mid-height max. spread with the bh sub-frame in place. I'd appreaciate that measurement greatly.
(INOP) JOHN DEERE LX186 RIDING LAWN MOWER (A65055)
(INOP) JOHN DEERE...
2015 Ford F-150 Ext. Cab Pickup Truck (A64556)
2015 Ford F-150...
(128) BOARDS OF 1"x6"x8" PONDEROSA PINE (A65055)
(128) BOARDS OF...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
2015 Dodge Charger Sedan (A61574)
2015 Dodge Charger...
2012 Ford F-450 4x4 Liftmoore 1640 4,000lb. Crane Service Truck (A64556)
2012 Ford F-450...
