Kubota drawbar hole diameter??
   / Kubota drawbar hole diameter?? #22
I attempted to put a 2" ball on my hitch on my drawbar this weekend and had no issue with the hole size; but the threaded post on the ball was only 1/8th longer than the thickness of the drawbar so it was impossible to attach the fastening nut. I need a ball with a longer threaded post on it. I did not have time to measure anything Saturday, so I have to wait til next Friday to look at this more closely.
   / Kubota drawbar hole diameter?? #23
I need a ball with a longer threaded post on it. .
If you can find one there are balls with an internal threaded hole for a bolt allowing you to accomodate any thickness.
I actually have a drawbar around I assembled years ago with a 1 7/8 ball on one side with a 2" on the other, using one ball with a hole screwed into the one with a stud. This was years before someone started marketing such an item.
BTW I bet the OP's Kubota hole is 25mm...that is a common metric size. I bought some wheels and tires from HF to build a logging arch and was stymied for awhile when I discovered the axles needed were not 1" (25.4mm) but 25mm. Turns out long hardened 25mm bolts used for axles are hard to find and cost a whole lot more than 1" bolts.:cool:
   / Kubota drawbar hole diameter?? #24
I bought some wheels and tires from HF to build a logging arch ...
Not to run up the pirate flag on the thread or anything, but do you have pics of the arch? I have one too, just curious.
Sean
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52577)
2013 UTILITY VS2RA...
Unused Delta Crash...
Pro Tech 16' Snowbox (A50774)
Pro Tech 16'...
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
Year: 2015 Make: Peterbilt Model: 320 Vehicle Type: Truck Mileage: Plate: Body Type: Trim Level: (A51692)
Year: 2015 Make...
AGT Agrotk 680 Drop Hammer Attachment (A47384)
AGT Agrotk 680...
