Kubota drawbar hole diameter??
   / Kubota drawbar hole diameter?? #22
I attempted to put a 2" ball on my hitch on my drawbar this weekend and had no issue with the hole size; but the threaded post on the ball was only 1/8th longer than the thickness of the drawbar so it was impossible to attach the fastening nut. I need a ball with a longer threaded post on it. I did not have time to measure anything Saturday, so I have to wait til next Friday to look at this more closely.
   / Kubota drawbar hole diameter?? #23
I need a ball with a longer threaded post on it. .
If you can find one there are balls with an internal threaded hole for a bolt allowing you to accomodate any thickness.
I actually have a drawbar around I assembled years ago with a 1 7/8 ball on one side with a 2" on the other, using one ball with a hole screwed into the one with a stud. This was years before someone started marketing such an item.
BTW I bet the OP's Kubota hole is 25mm...that is a common metric size. I bought some wheels and tires from HF to build a logging arch and was stymied for awhile when I discovered the axles needed were not 1" (25.4mm) but 25mm. Turns out long hardened 25mm bolts used for axles are hard to find and cost a whole lot more than 1" bolts.:cool:
   / Kubota drawbar hole diameter?? #24
I bought some wheels and tires from HF to build a logging arch ...
Not to run up the pirate flag on the thread or anything, but do you have pics of the arch? I have one too, just curious.
Sean
JOHN DEERE 8410T TRACTOR (A51243)
JOHN DEERE 8410T...
Bad Boy Outlaw XP61 Zero Turn Mower (A48082)
Bad Boy Outlaw...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
2008 Ford F-250 Knapheide Service Truck (A50323)
2008 Ford F-250...
48ft Low Boy T/A Trailer (A49346)
48ft Low Boy T/A...
2015 VANTAGE TRAILER CRUDE TRAILER (A50854)
2015 VANTAGE...
