kubota dilemma
/ kubota dilemma #21
Don't know if you have aquired your tractor yet. but after reading thru all the posts, something was missing. If you are going to use this for the lanscapeing business, then I feel a QA capable loader would be your best bet.
I am currently landscapeing my property and have used QA forks, QA Bucket, QA 3pt hitch and QA Hyd Auger.
I am not going to suggest which model to get since I went from a L3130 to a cabbed L5740 and am biased with the GL series.
I use the Hyd Auger for planting 60+ trees with a 24" auger, makes quick work for planting. I will be trying a 32" auger next week to see if it will work.
Having a QA capable FEL allows the use of other landscapeing attachments.
/ kubota dilemma #22
I started out with cub cadets for use in my business. 3 decades and 6 tractors later i found the right all around machine for our needs. The GL 3540. The loader has enough lift height to load a class 2 dump, the pto is powerful enough to run anything we need it to and the machine is light enough to fertilize & spray pristine turf with no footprint.
2022 Kubota SVL97-2 Compact Track Loader Skid Steer (A61572)
2022 Kubota...
2023 Mercury Verado 350HP Outboard Boat Motor (A61574)
2023 Mercury...
2023 26ft Freedom Trailers Akurate Dynamics T/A Mobile Spray Foam Trailer (A61573)
2023 26ft Freedom...
2021 Bobcat UV34 4x4 Gas Utility Cart (A61572)
2021 Bobcat UV34...
UNUSED WOLVERINE (A64281)
UNUSED WOLVERINE...
UNUSED AGT ATK- TC 24 TIRE CHANGER (A64281)
UNUSED AGT ATK- TC...
