Kubota diesel engine
/ Kubota diesel engine #1
UncleMerle
Lapeer, Michigan
2021 Mahindra 2660
My Skag mower with a 25 hp Kubota diesel engine has given me 13 years of trouble-free operation. On my first attempt to use it this season, the engine "popped" when I started it, and the exhaust began pouring out lots of dense black smoke. The exhaust sputters and makes a sizzling sound. The soot it left behind is dry and powdery and the crankcase oil level registers "full". The engine does not respond to the throttle. It struggles to run at low rpm's and stalls out in about 30 seconds. I can restart it, but with the same results. Oddly, if I try to shut it off with the ignition key, it continues to run for several seconds before dying out. What could be causing this situation and how extensive are the repairs likely to be? Would I be better off to pay for the repairs, or trade in a 13-year-old non-working mower for a new one?
/ Kubota diesel engine #2
Start by taking the air filter off and see what's the condition of it, since this is often overlooked. Sometimes creatures with make a nest inside the air cleaner and can create the symptoms you're experiencing.
I had previously checked the air filter, but in response to these suggestions, I ran it both with and without the air filter in place - no difference between the two. But now, instead of stalling out in a few seconds, it continues to run but sounds like it will stall. Still black smoke and no response to the throttle.
/ Kubota diesel engine #5
Sounds like pump or injector issues but could be a blocked fuel filter or bowl filter too.
I take it you are lax as far as maintenance is concerned.
You might want to PM PumpServiceGuy on here. he's the pump expert.
I'd be eliminating everything from the fuel tank (blocked fuel cap) to the pump first and that includes all filters as well as the brass screen filter in the pre pump bowl.
Thanks. Not lax - have the machine serviced annually. Correction about not stalling - it still stalls.
/ Kubota diesel engine #7
Black smoke indicates over fueling and its lack of power indicates too little fuel when needed. I'd check the injection pump to see if a bolt came loose and caused it to go out of time. I am not familiar with what drives the injection pump, but if it is a chain or belt I'd give that a close look as well.
/ Kubota diesel engine #8
I’d replace the fuel filter or filters if there is more than one. Then see what happens.
2023 Stearling Trailer (A60352)
2023 Stearling...
JOHN DEERE M15 - 15' BATWING ROTARY MOWER (A64277)
JOHN DEERE M15 -...
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A63689)
2023 Takeuchi TL6R...
John Deere 6200 Tractor (A64047)
John Deere 6200...
1981 Chevrolet Corvette (A62613)
1981 Chevrolet...
10' Rotary Hoe (A64126)
10' Rotary Hoe...
