Kubota D1105 replacement?
/ Kubota D1105 replacement? #1
MultiMow
Wytheville, VA
Toro 325-D 4WD
I have a turf tractor that's currently powered by an aging Mitsubishi K3D rated at 25hp. I've been told the Kubota D1105 (28hp) is a direct swap, as it was offered in the same chassis.
My hydro trans and PTO boxes are rated for 50hp. The axle is rated for 80hp.
I was just wondering if any other 3cyl diesels offer more horsepower with the same mounts. If I'm going to bother with the swap, I might as well go for all the power I can bolt in without modifications.
I'm not sure... but you, along with everyone I've spoken with, say the Kubota 1105 (28hp 3cyl) was a vast improvement.
By the way, Xfax... I've since sourced a killer deal on some air cooled 2cyl diesels. They're parallel twins, rated @ 20.5hp.
I know it would be a louder and weaker (although, I doubt my K3D retains more than 18hp) engine... but my thoughts are this:
#1- it would be lighter
#2- I could replace the OEM radiator with a high capacity dedicated hydraulic cooler and electric fan
#3- the higher operating RPM might let the hydraulics perform a bit more responsive, AND carry a higher blade speed and travel speed.
What do you think?
The price of the new engine is $600... about $500 less than a complete used Kubota 1105 with with all the ancillaries.
/ Kubota D1105 replacement? #6
Sounds interesting.
How about some pictures?
Sorry it took so long, Xfax... but my source lost the bid on those engines. He's always coming across deals. I'll keep you posted.
/ Kubota D1105 replacement? #9
No problem, I don't need one.
Was just curious.
2017 FREIGHTLINER CASCADIA  6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2017 FREIGHTLINER...
Location Tampa, FL (A61567)
Location Tampa, FL...
Landhonor Skid Steer 3Pt Hitch Adapter (A62679)
Landhonor Skid...
1995 MACK RD690S T/A DUMP TRUCK (A64277)
1995 MACK RD690S...
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
(2) Wheel Weights (A64127)
(2) Wheel Weights...
