Kubota D1105 - EF07 Engine Rolling Coal at Altitude
   / Kubota D1105 - EF07 Engine Rolling Coal at Altitude #11
A 3 percent loss of power per 1000 ft means at 10k it is down 30 percent. It probably even feels like it is worse than that too. You need some boost.
   / Kubota D1105 - EF07 Engine Rolling Coal at Altitude #12
Either some boost or some more cubic inches. For example if the implements you intend to run require 25pto horsepower you would need a 35PTO hp tractor at high altitude just to be net you the 25 you need to run the implement. Even then it would be advisable to have it tuned to run properly in thin air.
2007 GMC W4500 Landscape Dump Truck (A55788)
2007 GMC W4500...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A54811)
1996 JLG Commander...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
2022 CATERPILLAR 303.5CR EXCAVATOR (A52705)
2022 CATERPILLAR...
UNUSED LANDHONOR 82" FORK EXTENSIONS (A54757)
UNUSED LANDHONOR...
Mobile toilet with shower (A55758)
Mobile toilet with...
